Fuel tank filler neck
Think it will help.
https://www.ford-trucks.com/forums/1...placement.html
Wow. $44 for a piece of rubber hose. Does any one else think that's crazy? Oh well, what are you gonna do right?
So I started the job today and found that not only did the tank strap pull out of the frame but the 3 point strap broke when I took it down. Also found a leak in the brake line. So I spent the day cutting and welding the frame, replacing the fuel pump, and making a new brake hard line. Will reassemble tomorrow. Thanks for the help guys
rubber hose filler neck
Buster Joe Baker
11-17-2013 02:07 PM
