knock sensor location 87 f150 efi 5.0
Eric, mighty glad you showed that picture, the only thing i could see was the vacuum thingy under the arrowhead. I will get a ladder and mirror tomorrow to see if i can get my 26 inch legs and 46 inch waist where i can see. which brings up another something I just learned a month ago. you can change the pcv valve without taking that intake contraption off. thats when i remembered why I had 3 new pcv valves on the shelf. each time i did a tune up i bought a pcv valve and being rather short and some what squat couldnt figure why ford went brain dead and put a 2 1/2 inch long valve in a 1 1/2 gap. I wasnt about to pull an intake for a pcv valve. so at some point later on when i needed valve cover gaskets which was about as often as tune ups, i just took it to the dealer and said put in new pcv valve when you fix the leaking covers. Something about not admitting i didnt know how to change a pcv valve.
vjsimone
02-22-2017 11:43 PM
spag
21
05-10-2016 02:05 PM
rice975.0
01-25-2011 04:21 PM
Swede1
08-29-2007 08:42 PM
1990, 1991f150spark, 302, 50, 87, f150, ford, forum, knock, location50, senser, sensor, specifications, truck, working
