Looking at a '95 all wheel drive, $600. The owner says that the van will not restart after a drive, wait about 2 hours and the van will start right up.
Any ideas? Would like to buy this van. Really clean.
lots of potential problems and little info to analyze.
just guesses at this point
need more testing
please pull the codes per sticky thread at top of 1st page of threads
what engine, 4.0L?
1. failed coil pack, heat intermittent
2. failed Ignition Control Module, heat int.
3. failed Crank Position Sensor, "
4. failed ECT
5. failing PCM/ECU
Correction. The Areostar is '96, 4.0 engine, with 144.000 miles.
What is a FPR?
The van is 50 miles away. Contacted the owner for an appointment.
Thanks
These symptoms have broken Engine Temperature Sensor written ALL over. I had the same problem a few years back, put a new one in and she starts up every time no matter what the engine temperature is.
Start the engine & take a test drive, warm it up & then allow to idle, watch the exhaust & feel the engine response. If any hint of black smoke & bogged down throttle response, likely the engine is running rich when hot. If so:
Can be bad Engine Coolant Temp or Air Charge Temp sensors
Bad front Oxygen sensor
Bad Fuel Pressure Regulator or plugged vacuum line.
These are all relatively cheap & can be tested with a Multimeter except the Fuel regulator which is not a major expense either.
This engine is run by the OBD2 diagnostic/management system so if you can borrow a scantool you can monitor all the sensors & also check the I/M systems monitor. OBD2 is a very good system for detecting engine /sensor problems if you can do the detective work to follow up on the computer codes.
My first guess would be faulty ECT sensor seconded by stuck rich front O2 sensor, both can cause the described symptoms.
I am going to go against the grain and say Crank/Cam position sensor is going out on it. But like what has been said, a quick hook up to a OBD-II reader will give you the low down. Depending on the condition of other stuff (engine and tranny appear to be in good condition with the body), I would jump on that deal.
Just got home. Damn, the Bears and Packers are playing Sunday night football.
Ok here is what I found. The body is in great shape, no rust that I can see, rear hatch has cracks and the struts were hanging loose. No big deal.
However when I fired up the engine, which it did, like right now, massive amounts of white smoke came shooting out the tail pipe. The smell of coolent was almost overwhelming, according to my wife. Engine sounded good. a little bit fast for my taste though.
Now we know why the engine took so long to restart- HYDRO LOCK.
Just got home from looking at the 96. Missed most of the Bears And Packer game.
This is what I found. Good body, no rust from what I see. The rear hatch had cracks and the struts were hanging from the body, now big deal. Tires were new with receipts in the glove box. Brand new oil. Tranny fluid bright red, with no smells. OK so god so far.
Engine fired right up within 1 1/2 seconds. Revs were a little fast for me. Out of tail pipe, mountains of white smoke. Coolent smell very strong. Now we know why the van would not restart for awhile.
HYDRO LOCK
I passed on this van
