squealing noise when braking
Old Sep 7, 2009 | 01:26 PM
astarner74's Avatar
astarner74
I have a 2000 F-250 with an annoying squeaking noise the front drivers side only. When you apply the brakes it make a squeal and also riding on a rough road it squeals too. But after putting it in reverse it does not make noise at all, but will come back a few minuetes later. The brake pads a rotors are fine. Any answers
Old Sep 7, 2009 | 02:56 PM
agg_bagg's Avatar
agg_bagg
Ummm wheel bearings
they could be going out and the stress of the brakes makes them squeal.
Old Sep 7, 2009 | 07:29 PM
61 uni's Avatar
61 uni
Good luck. The drivers side rear does it on mine. Brakes are fine and I pulled the axle to check the bearings which felt great?
Old Sep 7, 2009 | 07:48 PM
Bigcat350's Avatar
Bigcat350
Are you sure the pads are fine. Sounds like the pad warning squealer is hitting the rotor. Just making sure.
Old Sep 7, 2009 | 07:55 PM
Trouble1263's Avatar
Trouble1263
This sounds like a chatter condition to me. Try removing the brake pads and apply a Thin coat of grease to the Back side of the pad. Also, if there is a notch on the pad , grease this contact area ...Good Luck.
Chasetgd
New Member Introductions
Feb 10, 2015 08:13 PM
BAD RONALD
Apr 24, 2014 02:39 PM
Albert Sanchez
1983 - 2012 Ranger & B-Series
Mar 16, 2014 11:14 PM
cat-977
Escape & Escape Hybrid
Apr 19, 2011 09:28 PM
