Loud Starter
Old Sep 6, 2009 | 10:52 PM
OrangeJuice's Avatar
OrangeJuice
Question Loud Starter
Hello,
I just replaced my starter the other day with a new one. When I turn the key the truck starts fine, but when I release the key from the start position it makes a loud '' ZIP '' noise. Any idea what's causing this? Is this a defective starter or will the noise go away after use?
Thank You
OJ
Old Sep 6, 2009 | 10:57 PM
peganit2's Avatar
peganit2
Never had a break in period for a starter before, so I think you have a bad one. Or a bad flywheel.
Why did you replace the starter in the first place?
Old Sep 6, 2009 | 11:07 PM
OrangeJuice
The flywheel and starter were replaced last year so I know the flywheel is good. The starter had to be replaced because the threaded post for the starter cable stripped-out. This starter is under warranty, so it can be exchanged.
Old Sep 6, 2009 | 11:24 PM
peganit2's Avatar
peganit2
Starter it is then. Good thing these things are so easy to service or I would be pissed if I were you.
Where did you get the starter?
Old Sep 7, 2009 | 08:45 AM
OrangeJuice
Well, yeah it's easy to service, but I have to remove the passenger side header to access the starter. No biggie...did it before. I got the starter from the local auto parts store.
Thanks for your help.
OJ
Old Sep 7, 2009 | 12:51 PM
peganit2's Avatar
peganit2
Really!? you have to remove the header? I have headers and I don't have to, and I have a big block!
Old Sep 7, 2009 | 01:14 PM
Tees77f150's Avatar
Tees77f150
I ran into this last fall, where I got a starter, and after laying out on the ground in the cold only to find out the starter was locked up! I called NAPA and they tried to tell me my motor was locked up!
After I educated them up on that, they said they had another on the shelf. I went back and had them bench test the starter while I waited. I could hear them back there testing it, so I know they did, and it worked.
Old Sep 8, 2009 | 01:05 PM
OrangeJuice
OK...I removed the header and starter yesterday and exchanged it for a new one. The auto parts store tried to tell me I must have a bad flywheel. I told them that's not the problem. They wanted to bench test the old one and I told them I wanted a new one. I asked them to bench test the new one and they did with no problems. Bolted everything back on and it started just fine without any issues.
Thanks
OJ
Old Sep 8, 2009 | 01:09 PM
Tees77f150's Avatar
Tees77f150
Thanks
OJ
GREAT, thats good to hear, sometimes you got to get a little firm with the parts houses in order to get through to them.
Old Sep 8, 2009 | 01:32 PM
OrangeJuice
Yup...they acted as if it was a big inconvienence for them to replace it.
Old Sep 8, 2009 | 06:01 PM
460me's Avatar
460me
I have a 79 Trailer Special with a 460 and Doug Thorly Headers.I can remove the starter with out removing the header.
BraidenSC
Oct 3, 2013 05:03 PM
waystro
Apr 4, 2013 09:10 PM
karlhr
1997 - 2003 F150
Feb 8, 2011 04:11 PM
orthogod1
Dec 28, 2010 06:35 PM
DJdemon6696
Aug 22, 2007 04:26 PM
