Sponsored by: Auxito
cab leaks
Old Sep 5, 2009 | 12:52 PM
arvtxrider1800's Avatar
arvtxrider1800
cab leaks
i have noticed that when it rains i have a leak into the cab of my 2000 f150 extended cab. the water is comin in from what appears to be between the headliner and back glass. what do i do to fix this?
Old Sep 5, 2009 | 02:18 PM
984x4F150's Avatar
984x4F150
Honestly, you probably live with it unless you want to drop $$$ on a new window. Ford had a technical service bulletin (TSB) on that window frame, but it's not a recall. I think it only affected the ones with the rear slider (like mine), but I could be mistaken. Mine has always leaked straight down the window, and never got anything IN my truck wet. It just bothered me enough 'til I bought some Liquid Nails stuff for roofing and filled the entire gap with it. Doesn't leak any more.
Old Sep 6, 2009 | 06:34 AM
Joe Finn's Avatar
Joe Finn
If you do a search, there are a few good posts on leaky rear windows. If I remember correctly, it can be fixed, but it's a bit of a pain to do. I called a glass shop and was quoted $260 for a replacement slider for mine.
Old Sep 6, 2009 | 09:02 PM
steve(ill)'s Avatar
steve(ill)
jump in the back seat, pull the plastic panels off around the side of the window, and fold the seat down and take that plastic off. look for a ring of bolts that holds the window/ frame in. take out the bolts, push windonw into the bed area. you need a new bytyl seal from Auto Zone. cost about $15 and takes 2 hours. No new window.
Old Sep 6, 2009 | 09:04 PM
steve(ill)'s Avatar
steve(ill)
look at these photos and do some reading. its not too hard. dont bend the head liner.
https://www.ford-trucks.com/forums/6...ar-window.html
Old Sep 7, 2009 | 06:21 AM
984x4F150's Avatar
984x4F150
Just a note, but I believe the problem with the sliders was the window frame itself cracks, so just a new seal will not help. Mine had at least 5 cracks in the frame, I can see them from inside the truck.
Old Sep 7, 2009 | 08:46 AM
steve(ill)'s Avatar
steve(ill)
if its the seal, it normally happens at the topp, by the head liner, about 12 -18 inches from the drivers corner toward the middle. Basically behind the drivers head. The seal was not installed correcly on the frame at this point.
Old Sep 10, 2009 | 09:37 AM
Eatonpcat's Avatar
Eatonpcat
Worked on my rear window, not hard...just a pain in the a$$
Red2003XLT
1983 - 2012 Ranger & B-Series
Nov 25, 2014 12:11 PM
Diesel wyatt
Sep 25, 2013 08:06 PM
78 & 87 Super Cab
Aug 2, 2013 10:08 PM
WVU
Oct 11, 2011 07:01 PM
WH90
Sep 20, 2011 06:16 AM
