fuel knock?
Old Sep 5, 2009 | 11:32 AM
2000 roadking's Avatar
2000 roadking
fuel knock?
2006 F150 5.4 100,000 + just tuned up new plugs [ that was fun! ] new gas filter,air filter ,oil&filter everything motorcraft [old plugs look normal.] After driving truck all day , sometimes at highway speeds you feel a slight skip engine seems to lose a little power. The check engine light will begin to flash. If you take it out of overdrive it straightens out.No codes except once it showed [misfire #4 cylinder] I checked everything out it seemed fine also it has never set that code again. Sometimes when all this occurs there will be a LOUD KNOCK! something like a diesel might make.Any help would be great Thanks.
Old Sep 5, 2009 | 11:54 AM
FTE Trigger's Avatar
FTE Trigger
At first I'd say possibly a Cam phaser... (diesel noise)
...but since you just completed all those PM related items, I'd start looking at a possibly damaged or a flakey connection on a COP?
Old Sep 5, 2009 | 06:44 PM
2000 roadking
Thanks for reply [what is cop] ? sorry this engine is new to me. If you are suggesting that I might have distured something, the engine was doing this before tune up. what is a Cam phaser and what is it's function and is it possible to repair or replace with out a bunch of tools? Thanks again.
Old Sep 5, 2009 | 07:28 PM
BlueOvalFitter's Avatar
BlueOvalFitter
COP= Coil On Plug
Brad Ramthun
18
Mar 6, 2025 01:07 AM
schlik83
Aug 8, 2020 08:21 AM
jduckworth18
Mar 27, 2015 11:29 PM
2000 roadking
2004 - 2008 F150
Sep 7, 2009 06:57 PM
kcomer
May 11, 2003 01:27 PM
