Message Board Upgrade
Old Nov 14, 2001 | 12:41 PM
  #31
TallPaul's Avatar
TallPaul
The new software is great. Two problems I am having:
1) When I upload a picture I get only the filename and have to manually copy and insert the path.
2) I was limiting use of my signature so as not to have threads clogged up with the low RPM tachometer photo several times over. Seems now I have no control. The signature is on all posts. Is there a way I can delete it from messages as I am editing? Right now I deleted the tach from the signature and can add it as an attachment at times.
Old Nov 14, 2001 | 12:43 PM
  #32
TallPaul's Avatar
TallPaul
Well, Obviously that didn't work. Should have tried it in the test forum first. Sorry.
Old Nov 14, 2001 | 09:52 PM
  #33
Neil's Avatar
Neil
Smilies don't work!
Everytime I try to add a smilie (the little green guy is jumping hopping up and down right now) nothing happens. I just clicked on him, he freezes, and a little yellow triangle at the lower left of the screen appears that says "error on page" Is it me or is there a problem elsewhere?
Old Nov 14, 2001 | 10:44 PM
  #34
dust3's Avatar
dust3
I am also having to login everytime, even after playing around with user preferences.
Old Nov 14, 2001 | 11:08 PM
  #35
FTE Ken's Avatar
FTE Ken
>Ken-
>One suggestion. With the upgrade, unread posts are supposed
>to be identified with colored icons. I couldn't figure this
>out until I logged on at work, whereupon I did see a slight
>blue tinge on the unread posts icon. Apparently my monitor
>at home cannot adequately display such a small color
>difference. Would it be possible to darken the shade of the
>color icons? Thanks.
>Jerm
I've fixed the two that were the most problematic. The others will remain unchanged until I have more time.
Old Nov 14, 2001 | 11:10 PM
  #36
FTE Ken's Avatar
FTE Ken
I'll look into this.
The solution is to change your signature and insert the tach photo manually. The signature is now kept seperate so if you change it all your posts using it will change when all the threads go throw their weekly rebuild....
Old Nov 14, 2001 | 11:11 PM
  #37
FTE Ken's Avatar
FTE Ken
>Smilies don't work!
Now fixed.
Old Nov 14, 2001 | 11:12 PM
  #38
FTE Ken's Avatar
FTE Ken
Turn cookies on in your browser.
Old Nov 14, 2001 | 11:13 PM
  #39
Neil's Avatar
Neil
[updated:LAST EDITED ON 15-Nov-01 AT 00:16 AM (EST)]Thanks Ken
Added in edit:
Oops, maybe not fixed yet? All that showed up on the screen after this original post was the two O's behind you name.
Old Nov 15, 2001 | 08:13 AM
  #40
TallPaul's Avatar
TallPaul
Ken, My mix up. I was using the message attachment to upload my Avitar and when I got to the Avitar input screen had to add the file path. I now see that the file path is automatically there for message attachments and have successfully uploaded a message attachment. So no problem here. Though I notice others have had the same problem with the Avitar that I had.
Old Nov 15, 2001 | 08:16 AM
  #41
TallPaul's Avatar
TallPaul
Old Nov 16, 2001 | 05:46 PM
  #42
Neil's Avatar
Neil
>>Smilies don't work!
>Now fixed.
Ken, I'm still having problems with the smilies. I tried to use the green jumping guy again today and all that shows up in the post is 0o.
Thanks,
Neil
Old Nov 16, 2001 | 06:03 PM
  #43
FTE Ken's Avatar
FTE Ken
>>>Smilies don't work!
>>Now fixed.
>in the post is 0o.
>Thanks,
>Neil
Its a known bug in the code from the vendor. When they release a patch I'll install it.
Old Nov 20, 2001 | 08:08 PM
  #44
Debby's Avatar
Debby
I just realized that someone has already said something about the smilies...I thought it was me...Thanks Ken for all your hard work!
Deb
Old Nov 22, 2001 | 08:54 AM
  #45
58f100's Avatar
58f100
hi ken looks good the change does , i downloaded msn 6 and have had trouble, i dont see how to expand the text anymore, i dont know if its me ?? or the updates. the innernet tower of babble in msn has me sppoked, but i want to leave a pic of my 58 when i message anyone, have to figure it out ?? soon my 58 will be home , i say thanks again for the emblems they look great
garry
58f100
