Message Board Upgrade
Old Nov 11, 2001 | 04:38 PM
FTE Ken's Avatar
FTE Ken
>As of 1630 on 11/11 I still have to login each session.
>Since you listed that as fixed in an above post, I'm
>assuming it's a Netscape-related glitch. Not a major issue
>by any means but it could stand some attention when you get
>the time.
On the main forum screen click your user settings button. You can select there that you want it to remember to keep you logged it. Unfortunately when the software upgraded everyone it set this to off by default. Its now on by default for all new users but everyone who was imported from the old system will have to change it if they want to stay logged in....
Old Nov 11, 2001 | 04:43 PM
murphydo's Avatar
murphydo
[updated:LAST EDITED ON 11-Nov-01 AT 06:32 PM (EST)]what does the avatar image do. I am trying to figure this stuff out, dont' know if i got it or not. i want to put of picture up above my name when i post and seeing how to put a pic with my sig.
1987 F150 2wd, 4.9L, 4 spd manual
3" suspension, 3" body lift with 31's
168,000 and counting
Old Nov 12, 2001 | 10:16 AM
FTE Ken's Avatar
FTE Ken
One thing to keep in mind is that if your host doesn't serve up images fast (such as your avatar) you're slowing down browsing for everyone viewing your messages. Upload your avatar image to this site in a post and then link to it.
Old Nov 12, 2001 | 10:45 AM
murphydo's Avatar
murphydo
Old Nov 12, 2001 | 11:17 AM
RJKobbeman's Avatar
RJKobbeman
What I noticed right away is the subject length has changed. Everytime I reply to a post, I have to shorten the subject.
Don't know if this is a bug... or just the way you intended.
This board does really rock!
Old Nov 12, 2001 | 12:23 PM
Shepard's Avatar
Shepard
I like the changes to the new site with the one following *constructive* suggestion. When I click on "read new", all I need are the new messages. The large portion of the screen taken up by the search stuff is not needed. I liked the old read new screen much better than just having all the new message listed in the little box down the right side of the page.
Old Nov 12, 2001 | 05:02 PM
weldman's Avatar
weldman
Post Message Board Upgrade
[updated:LAST EDITED ON 12-Nov-01 AT 06:17 PM (EST)]Keep up the good work ken!
Get well!!
Old Nov 12, 2001 | 08:09 PM
jagabom's Avatar
jagabom
Looking good man.
Old Nov 13, 2001 | 04:52 AM
FTE Ken's Avatar
FTE Ken
>page.
The search stuff isn't optional in the new version. Its there to allow you to refine and filter read new results. I've made that part of the screen narrower but I can't remove it.
Old Nov 13, 2001 | 10:08 AM
Jerm's Avatar
Jerm
Ken-
One suggestion. With the upgrade, unread posts are supposed to be identified with colored icons. I couldn't figure this out until I logged on at work, whereupon I did see a slight blue tinge on the unread posts icon. Apparently my monitor at home cannot adequately display such a small color difference. Would it be possible to darken the shade of the color icons? Thanks.
Jerm
Old Nov 13, 2001 | 08:07 PM
oleblue70's Avatar
oleblue70
....couldnt acsess the chat even though logged in??????
Otherwise very nice
Old Nov 13, 2001 | 08:10 PM
oleblue70's Avatar
oleblue70
Also,what is a Charter member?Also,it has me as a new user.I have been a faithfull registered member since Oct
'99.
Old Nov 13, 2001 | 08:17 PM
  #28
FTE Ken's Avatar
FTE Ken
>Ken-
>Jerm
This one is going to have to be a real low priority. There are over 40 icons that would have to be edited and I'm far too busy to spend half a day editing gif files..... when it slows down I'll get to it.
Old Nov 13, 2001 | 08:20 PM
  #29
FTE Ken's Avatar
FTE Ken
>'99.
The old system didn't assign users a "registered since" date. All users imported from the old system are considered "charter." As far as the system is concerned EVERYONE is new for a while since it didn't date anyone before.
Old Nov 13, 2001 | 11:14 PM
  #30
weldman's Avatar
weldman
I still am having trouble with staying logged in when I return to FTE, even though I've turned the feature on and off several times in my preferences. Anyone else having this problem?
As well, can someone explain to me how I get email notification to threads now? On some threads when I post, the box is there (like this one), but on others it isn't.
Thanks!
Matt
