i got a question
Old Sep 3, 2009 | 01:55 PM
fdude64's Avatar
fdude64
i got a question
i just bought a 84 f250 2wd for the 7.5 460 it has in it. i am going to put it in my 79 f250 4x4 it now has a mid 70s 460 in it. what kinds of differences are there in these two motors?
Old Sep 3, 2009 | 02:22 PM
Ronzi's Avatar
Ronzi
Not a whole lot. 1979 they went to externally ballanced motors so if the motor in your 79 is a 78 or older its internally ballanced and your flex plate or flywheel wont work on the newer externally ballanced motor.
Old Sep 3, 2009 | 02:32 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
This occured MIDYEAR 1979, not at the beginning of the model year.
This was a running change, so...there is no serial number or production date break.
The following info comes directly from the 1973/79 Ford Light Truck Parts Catalog:
Block casting numbers used in 1979 460 F100/350's and Econolines:
D1VE-6015-AB, AB1, AB2: 1971/73 429 & 1971/79 460 do not use a weighted spacer.
D9TE-6015-AB introduced midyear 1979, uses a weighted spacer. The harmonic balancer and flywheel (flexplate) are not the same as used with the DIVE blocks.
No 460 engines were installed in 1979 passenger cars. 1978 was the last year.
1983 was the first year that Ford offered a manual transmission with the 460.
1972fordhighboy2
Oct 4, 2016 12:15 PM
TNT79Bronco
Sep 16, 2014 12:47 PM
Declan F250
Jul 18, 2014 05:43 PM
hatchet
Aug 22, 2009 01:12 AM
Ryans460
Exhaust Systems
Jun 24, 2001 08:09 PM
