Great site. If your doing just 4 wire trailer wiring here is a good way to remember where the wires go.Green is for the right side signal because the grass in the ditch is green. Yellow is for the left because the line down the centre of the road is yellow.Brown is the dark one so its for the park lights.White is your ground and I quess you see the white light just before you end up in the ground.
good info.... thanks Bob tomorrow we have a 45' trailer to figure out why the brakes won't work on two trucks and will on the other trucks... this will come in handy
later
John
Check the one that works first - when you screw that up every thing will be alike.
I hope those 45' trailers got more than a 4 pin flat hooking them up!
yep.... 6 pin standard for a gooseneck... I think it's just corroded terminals in the plug... construction folks fix most things by beating on it... I get to repair what they fixed...
you know the old saying... if you can't fix it with a hammer...it's an electrical problem
I've been told a horse trailer is wired differently than other trailers. I even had someone show me in a book the difference. My friend bought a used Ford F-350 dually that he thought was owned by a horse rancher. When he hooked up his car trailer the brakes didn't work but the first time he turned on his headlights the brakes locked up. He hadn't used the trailer at night until he owned the truck for a few weeks and when it got dark one night he flipped on the lights. He had to rewire the light socket on the truck to make the trailer work.
Any one else have experience with horse trailer wiring?
