Brake Problems
Old Sep 1, 2009 | 12:34 PM
rdikes10's Avatar
rdikes10
Brake Problems
Brake problems, I have a 93 F250 and the brakes suck.
I have replaced a caliper and rear brakes bled the lines over and over, I still don't get any back brakes, I have adjusted them with the truck lifted until they grab but when I drive they still don't seem to work. I bled the fronts and have great pressure there but from the proportioning valve to the back breaks it barely drips out when I bleed them, does this mean the master cylinder is no good?
Old Sep 1, 2009 | 12:58 PM
alxsnmr's Avatar
alxsnmr
do you have fluid from the master to the ABS module (its not a porporting valve that is at the master cylinder in line to the brake line)?
Old Sep 2, 2009 | 03:15 PM
rdikes10's Avatar
rdikes10
yes there is fluid to the ABS, but when I opened the bleeder valve it barely had droplets coming out, and that is with the valve completely opened
Old Sep 2, 2009 | 03:39 PM
andym's Avatar
andym
There is a bleeder valve on the ABS module, but it could be a bad module. They are a pretty common item to fail and when they do they usually keep the rear brakes engaged while driving which leads to a lot of problems.
If you want to fix it once and forget about it, bypass the valve with a piece of brake line. You'll never have to worry about it again!
rbruno
Aug 29, 2013 11:58 AM
460 FORD MAN
Offroad & 4x4
19
May 11, 2013 07:31 PM
DaRooster911
Oct 17, 2011 03:40 PM
sublauxation
25
Aug 8, 2011 11:41 AM
thunder31634
Sep 13, 2009 12:33 AM
