Sponsored by: Real Truck
need help
Old Aug 31, 2009 | 06:33 PM
RobH1965's Avatar
RobH1965
Cool need help
My first mistake today was to wash the truck and armorall the tires. 99 F250 S/D 4X4, V10, auto trans,430 Gears. 63K Miles original owner, and never beaten. I start the truck and leave my house and I notice that the truck is shifting from 1st to 2nd very hard. I then look down at the tach to check the RPM that it is shifting and I see both the ABS and the Service Engine Soon light on. Get to my destination about a mile from my house and check all the ususl suspects tranny fluid level ok and clean, fuse #15 which is for ABS and engine/tranny control modules ok???
Old Aug 31, 2009 | 06:38 PM
Fordfanatic4life's Avatar
Fordfanatic4life
did u wash under the hood ???
Old Aug 31, 2009 | 09:24 PM
FireMe's Avatar
FireMe
And does the speedo work?
Old Aug 31, 2009 | 10:56 PM
RobH1965's Avatar
RobH1965
need help
speedo works and did not wash under the hood
Old Aug 31, 2009 | 10:59 PM
Mustang6147's Avatar
Mustang6147
I would start simple, and check all your grounds under the hood...
That is really strange, considering you didnt wash under the hood...
I would pay close attention to the trailer wireing in the back, You might have a cracked brake wire, or ground, and electricity is feeding back threw...
Old Sep 1, 2009 | 07:23 AM
RobH1965's Avatar
RobH1965
'need help'
Correction, I drove the truck this morning and the speedometer does not work.
Old Sep 1, 2009 | 08:01 AM
Sarge261's Avatar
Sarge261
Sounds like you have a bad speed sensor in the rear and or broken wire to it. Do you have acess to a scan tool that will show you data. You should be able to see MPH in the PCM or TCM with a scan tool. With the symptoms you are describing I bet you wont.
Also if you can get to a autozone they have code readers so you can atleast get the codes in it and go from there.
Kepp us posted.
Sarge
Old Sep 4, 2009 | 02:52 PM
RobH1965's Avatar
RobH1965
I brought the truck to a good friend of mine who just happens to own a shop. He checked it on his scanner and found no output from the speed sensor. He cleared the codes and changed the speed sensor and I am back in buisness. Thanks for the guidance.
pawpaw
1983 - 2012 Ranger & B-Series
48
Mar 26, 2023 11:28 AM
Forced347sn95
1997 - 2003 F150
Nov 15, 2008 10:12 AM
Meat_fire
Feb 2, 2008 06:02 PM
Meat_fire
Jun 6, 2003 04:44 PM
tman701
Nov 15, 2002 11:05 PM
