Help
Old Sep 6, 2009 | 02:22 AM
  #31
2000ca250's Avatar
2000ca250
Fixed it! Sure enough when i got the covers off both harnesses were unplugged. Glad i bought replacements because the old ones were incredibly loose at the connections. Truck runs great now and sounds like it might even be running better. Anyways thanks for all the help guys. One final question. There was a lot of oil in my intake and all the tubes even after the intercooler. Looked like it was comin from that breather valve on the vc. This normal? A way to fix it?
Old Sep 6, 2009 | 03:43 AM
  #32
ChunderDownUnder's Avatar
ChunderDownUnder
Yes this is normal m8. A CCV kit is your answer.
there are cheap ones
http://www.riffraffdiesel.com/mm5/me...Category_Code=
and there are expensive ones
https://www.shopatron.com/products/c....29145.0.0.0.0
Glad you worked out your UVHC. very common with a simple fix
http://www.auto-mundo.info/videos/fo...esel-UVCH.html
50 cents in total. not bad hey.
Old Sep 6, 2009 | 01:52 PM
  #33
Stewart_H's Avatar
Stewart_H
New harnesses won't permanently solve the problem.
Did you bother to click on the link posted by Pete (Duck Fan) in post #12 and Greg (SuperDoodie) in post #24?
That link informs you that these UVC clips...
...which cost a few bucks at any Ford dealership, were created specifically for the problem you just encountered, and they're a lot cheaper than two brand new harnesses, which will not permanently fix the problem to begin with.
And if you didn't wanna buy the clips at your local Ford dealership, you can do what a lot of guys here have done, and use a quarter for each harness connector, grinding the sides to make them fit.
Why does the old adage, "You can lead a horse to water..." come to mind right now?
Stewart
Old Sep 6, 2009 | 02:05 PM
  #34
SuperDoodie's Avatar
SuperDoodie
Glad you got it fixed.
acwd1950
May 9, 2011 08:35 AM
Robert6401
82
Feb 28, 2011 10:56 AM
Weatherman1
May 13, 2008 08:30 AM
tjbeggs
Jan 31, 2006 06:00 AM
powerstrokefreak
Jan 21, 2006 02:20 PM
