PO-460 Code?
Old Aug 31, 2009 | 03:28 PM
dentaldave's Avatar
dentaldave
PO-460 Code?
The little light (engine needs service) came on the other day.
I took it to a buddy that has a scanner deal.
He said it showed a error code of PO-460.
"Fuel Level Sensor A Circuit"
Anyone have any thoughts or suggestions to what it going on?
I think it is obvious I don't know what I am doing but I would appreciate some help or advice.
2006 F250 6.0 41k
dentaldave
Old Aug 31, 2009 | 05:20 PM
npccpartsman's Avatar
npccpartsman
It's possibly dash related or the fuel level sensor in the fuel tank. I thought there was a TSB or possibly a recall on this because of a bad gauge in the dash panel, but I could easily be mistaken here.
Old Aug 31, 2009 | 06:32 PM
bismic's Avatar
bismic
SERVICE PROCEDURE
  1. P0460 can be caused by the installation of aftermarket equipment such as remote starter systems and auxiliary fuel tanks.
    1. Ford offers a remote starter system which is recommended. If the vehicle has an aftermarket remote starter system, it would need to be removed / disabled before diagnostics for P0460 can be started.
    2. Auxiliary fuel tanks that continuously replenish the vehicles main tank will cause a P0460. Customers that replenish the vehicles fuel tank from the auxiliary fuel tank while the key is on and engine is running, can set P0460. For vehicles with an auxiliary fuel tank, it is recommended not to use the gravity / continuous fill style auxiliary fuel tanks. It is recommended to add fuel to the vehicles main tank with the key off.
      <TABLE border=0><TBODY><TR><TD width=80>NOTE:</TD><TD>P0460 CAUSED BY AFTERMARKET EQUIPMENT/VEHICLE MODIFICATIONS IS NOT COVERED UNDER WARRANTY.</TD></TR></TBODY></TABLE>
  2. If there are no aftermarket equipment installed causing the P0460, perform PC/ED Pinpoint test QH and Workshop Manual (WSM), Section 413-01 Pinpoint Test B as directed. If no issues are identified per the procedure, reprogram the powertrain control module (PCM) to the latest calibration using IDS release B43.4 and higher. This calibration contains a revised strategy to eliminate the occurrence of a false P0460. Calibration files may also be obtained at www.motorcraft.com.
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage And Emissions Warranty Coverage
OPERATION
061311A Operation A
DESCRIPTION
2005-2006 F-Super Duty/Econoline, 2005 Excursion 6.0L: Check For Diagnostic Trouble Codes And Reprogram The Powertrain Control Module: (Do Not Use With 12650D, 12650D84)Operation MT: Claim Additional Labor Required As Actual Time Or Use SLTS Operation If Available: Actual Time 0.7 Hr.
Old Aug 31, 2009 | 08:38 PM
npccpartsman
BISMIC= Braniac Is So Much In Control of the TSB stuff it's unreal. I told ya Dave. Mark is the man with the plan.
Old Aug 31, 2009 | 10:14 PM
powerstroke72's Avatar
powerstroke72
Originally Posted by bismic
SERVICE PROCEDURE
WARRANTY STATUS:
OPERATION
061311A Operation A
DESCRIPTION
I dug around earlier and tried to find that Mark. Geez, you're good. I tried to rep you again and again, the rep police won't let me. You ought to have 10-15 of those little greenies for rep!!! Great info!
Old Sep 1, 2009 | 08:26 AM
dentaldave's Avatar
dentaldave
Bismic,
Thanks for the answer! That made my brain hurt. I don't have a auxiliary tank that is connected to the fuel system... just one in the bed that I fill from with a manual pump. My buddy (father in law) reset the light so it is not on any longer. He said I might just want to wait and see if it throws a code again. He said I might of just had a loose gas cap.
Do you think I taking a chance on harming the engine by doing this. I have a trip this weekend and don't want to do any damage to the truck?
Should I head to the dealer for the PCM reprogram or just wait to see if it throws a code again and then head to the dealer?
Thanks agian for taking the time to answer!
Dave
Old Sep 1, 2009 | 09:05 AM
npccpartsman
It shouldn't cause any engine damage at all. You should be just fine driving the truck, but if it occurs again then head to the dealership and let them do the reprogram. I think it's basically just a programming error anyway by your explanation and reading the service procedure.
Old Sep 1, 2009 | 04:17 PM
dentaldave's Avatar
dentaldave
Thanks npccpartsman, Quick question...
Say for example I knew a buddy who had a cat-delete pipe in place... would he be advised to put the cat back on before going to a dealer for reprogramming? Just curious.
dave
Old Sep 1, 2009 | 04:21 PM
npccpartsman
I wouldn't do it for a simple reprogram as there is nothing to tell the tech the Cat isn't there. He would physically have to crawl under and look. Besides that, if the dealer is that **** then your buddy needs to try and find another dealer as the cat doesn't affect the performance of the truck mechanically in any way UNLESS it gets stopped up.
Old Sep 1, 2009 | 04:37 PM
bismic's Avatar
bismic
good advice npccpartsman!
Mr f250
Feb 21, 2016 11:25 PM
tomeug69
Dec 10, 2015 08:48 PM
cornstar6207
Sep 14, 2013 02:34 PM
Jerry2197
1997 - 2003 F150
Jun 22, 2009 03:45 PM
dentaldave
Nov 6, 2008 10:21 PM
