Another Adrenaline Ordered
Old Aug 31, 2009 | 09:54 PM
  #31
mechelement's Avatar
mechelement
During my search, I've read that this new HPOP will eliminate the need for the HPX line. I thought the purpose of the HPX line was to equalize the pressure on both rails. If so, wouldn't the pump constantly provide an increased volume flow over the stock form pump? Does this pump help with injector starvation, cackle, etc.?
  #32
Tenn01PSD350's Avatar
Tenn01PSD350
Bob swore up and down that there would be no tuning changes needed when I spoke to him at the TS event. It would just provide more volume easier based on what my tunes called for. I walked away with a cool hat and some ideas. The price is right on that pump if you have problems.
Did I read that the intro price is over?
Old Aug 31, 2009 | 09:59 PM
  #33
Bigcat350's Avatar
Bigcat350
Mike todays the last day for $469.00. Goes up to $589.00
Old Aug 31, 2009 | 10:00 PM
  #34
hucka1a's Avatar
hucka1a
Originally Posted by Izzy351
Not yet. I wasn't even planning to until the North Texas event coming up in Oct. Right now, the plan is to put the pump in and see how it reacts. I'll definitely post up the results and whether or not any tuning changes are needed.
Sounds good to me.
Old Aug 31, 2009 | 10:01 PM
  #35
mechelement
Apples to oranges, man. You're talking about taking a motor that was never designed with a turbo in mind and slapping one on it. In this case, we're taking a HPOP system that was designed to run at a certain PSI, but because of tuning changes, can't keep up with the volume so the pressure drops. With stock tunes, the pressure doesn't drop because there isn't nearly the volume of oil required to pump the fuel stock tunes call for.
Ok, so this pump basically has the on-demand capability to provide enough volume flow (thus increase in pressure head?) when required. How advantageous is it to install this pump first, in mostly stock form?
Originally Posted by Bigcat350
Jason I explained it to my wife kinda like that also but she still want go for it. She said it want make my truck run faster, jump higher or smoke more. That just shows what she knows about it She said its time for her to get a mod she has new carpet samples on the counter, looks like thats were my new hpop $$ will go for now.
Hey, you're lucky your wife is looking at carpet. Mine looks at stuff having to do with horses.
  #36
Tenn01PSD350
I'll wait until it goes back down or he can keep it. Mine is doing OK.
Old Aug 31, 2009 | 10:09 PM
  #37
PaysonPSD's Avatar
PaysonPSD
Thanks for the info, Robin!! Reps if I can...
EDIT: DAMMIT!! I'm in Rep-Jail, Robin...
Thanks Joe. It's the thought that counts.
Old Aug 31, 2009 | 10:10 PM
  #38
Izzy351's Avatar
Izzy351
I just read that today. I have the hard HPX installed, so the likely hood of a failure is pretty slim. However, his logic if I understand it right, is that when the check-valve springs are removed from the output side, the volume is automatically balanced.
Old Aug 31, 2009 | 10:19 PM
  #39
mueckster's Avatar
mueckster
I thought about leaving my SS HPX on when installing the Stealth, but opted to remove it. I didn't really think it would make that much difference. I had a slight seep from one of the HPO rail O-rings and wanted to remedy this. Without the line, it will be a bit easier to remove my turbo next time I need to.
Old Aug 31, 2009 | 10:29 PM
  #40
mechelement
I'm not sure what check valves you're referring to. I'm not trying to argue anyone here on this subject and I'm not trying to hijack your thread. I think it's great that you're getting this pump and look forward to reading your observations. I'm only trying to understand this thing more so I can better explain it. If this pump is a good thing to have installed, even before a DP Tuner, better turbo, etc. I want.
Old Aug 31, 2009 | 10:34 PM
  #41
Izzy351's Avatar
Izzy351
No worries!! That's what threads are for! There are springs in the output connections that act as check valves. They are removed with the Adrenaline, so there shouldn't be a need for balancing the two heads anymore. They are both fed the same exact same pump pressure since the springs are no longer used. Have a look at page two:
http://www.dieselsite.com/pdffiles/a...structions.pdf
Old Aug 31, 2009 | 11:09 PM
  #42
hucka1a's Avatar
hucka1a
I did some digging around and it seems that most of the tuning issues are with trucks running stock injectors. Stock sticks seem to be more sensitive to the extra volume.
Old Aug 31, 2009 | 11:22 PM
  #43
spdmpo's Avatar
spdmpo
Hey Joe did you go ahead and have him add a rebuilt IPR with your order? Just curious, I did since I'm under the impression it's common for them to go bad after swapping the HPOP.
Old Sep 1, 2009 | 12:00 AM
  #44
PaysonPSD's Avatar
PaysonPSD
Huck,
Did you see my data logging post after swapping my 15° pump for the Adrenaline? If not here it is. LINK This is with the stock AB injectors
and tuning for the stock pump..
Old Sep 1, 2009 | 08:34 AM
  #45
Orezona's Avatar
Orezona
Price goes up tonight at midnight. They are counting down
GET YOUR ADRENALINE HPOP AT THE $469 INTRO PRICE THROUGH SEPTEMBER 1, 2009 AT MIDNIGHT. The introductory pricing for the Adrenaline High Volume High Pressure Oil Pump will end September 1, 2009 at midnight. All orders placed through that date/time will be honored at the $469 intro price. The Adrenaline MSRP is $589 and will go into effect starting September 1, 2009 at midnight.
0 days 14 hr. 21 min, 21 sec.
