Pyrometer thermocouple installation location
Old Aug 27, 2009 | 09:30 PM
aldridgec's Avatar
aldridgec
The manifold is thicker, but softer metal than the stainless up pipe. I think the up pipe would still be the easier spot. I've only use the manifolds on my installs.
Old Aug 27, 2009 | 09:44 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Originally Posted by derck_mullin
True...but don't think anyone wants to tap thru all 8 leads (that would be the only way to be technically correct)...plus drilling through the exhaust manifold would suck
I see what you are saying but you want an aggregate of the temp going to the turbo from the manifold. This is more about melting pistons than damaging the turbo. That is why post turbo or down pipe pyro installs are less desirable.
Yes, ideally it would be nice to see if I was about to melt piston 2, but that would require 8 pyros and gauges. Best measure then is at the manifold itself or as close to it on the up pipe. This leaves the passenger side to fend for itself as you assume that is the same. That is where a DP installed sensor can average but we have no idea how much cooling effect the turbo has for sure. The rule of thumb is about 200*. Since guessing is not cool, we go as close to one side as we can and assume the other is similar.
Pyros are not to save your turbo but to prevent melting a piston. Of course timers do help prolong the bearings in the turbo when they are hot so do not dismiss this. Never shut down a turbodiesel with high egts because it can supposedly cook the oil in the turbo bearings.
Old Aug 27, 2009 | 09:49 PM
bcg's Avatar
bcg
Thanks for the clarification. I do know what the exhaust manifold is, I've actually rebuilt gas engines but am still learning with diesel and turbos. I can follow the manifold out to the up pipe and figure it out from there.
Old Aug 27, 2009 | 09:54 PM
derck_mullin's Avatar
derck_mullin
Mike,
Yep, you got it. To be totally right you'd have to measure each port. Not practical so go for the up-pipe. Good as anyone can expect.
And as a correction the EGT is not to measure a turbo melting temp...it's to measure what is going on in the combustion chamber. The turbo will only sustain damage if the pistons have done the same. At that point YER DONE!
Old Aug 30, 2009 | 07:57 AM
bcg's Avatar
bcg
Thanks, everyone, for the help. I was a little worried about installing the thermocouple but the info you guys gave me got me in the right spot and it was really a breeze. Installing the tranny temp sender took more time than putting in the pyro thermo.
Old Aug 30, 2009 | 09:37 AM
farmdad's Avatar
farmdad
To go along with what you have said, Dan, Kwikkordead, has a double pyro with probes on both up pipes. This shows what each side is doing which gives you twice as much info as a single. It is a little pricey though.
Norma stitz
Nov 30, 2016 11:57 PM
scottddove
Sep 23, 2016 06:04 PM
BjornF16
All Other Items for Sale
Sep 9, 2016 08:21 PM
rolape2
Mar 8, 2012 04:41 PM
George D.
General Diesel Discussion
26
Feb 23, 2008 01:25 PM
