Blowing A Fuse
Old Aug 27, 2009 | 09:58 AM
GloveGuy's Avatar
GloveGuy
Blowing A Fuse
Hi there,
In my '89 F450 SD I've suddenly started blowing the fuse on the clearance lights. I did a count and I'm running 16 lights on the circuit that are the small lights like on the top of the cab and clearance lights around the flat deck. The weird thing is I've had this light configuration for about 2 years and everything has been great up until about 2 weeks ago.
The only difference I can correlate is I'm noticing that my battery light is flickering intermittently on the dash. Could something in the alternator be the problem?
Any suggestions are greatly appreciated.
Regards,
Barry
Old Aug 27, 2009 | 04:38 PM
BPofMD's Avatar
BPofMD
FTE Remembers
Veteran: Navy
Sounds more like an intermittent short to ground to me - in whatever circuit the clearance lights are in. Does it STILL flicker when the fuse is blown?
Old Aug 27, 2009 | 11:39 PM
GloveGuy's Avatar
GloveGuy
Yes, the fuse is blown, as we speak, and the battery light on the dash is still flickering intermittently.
Thanks,
Barry
Old Aug 28, 2009 | 12:12 AM
madpogue's Avatar
madpogue
Well that suggests an alternator / charging issue independent of your lights / fuse issue (since the light circuit is "open" with the blown fuse). The usual suspects - alternator itself, drive belt, main wires to battery.
As for the light issue, one way to verify that it's independent of the alt. issue - shut off the engine, put in a fresh fuse and turn on the lights. If the fuse blows even with the engine not running, that problem can't be related to the alternator, since, well, the alternator's not turning.
"Brute force" light diagnosis - remove ALL the clearance light bulbs, put in a fresh fuse and turn on the circuit. If the fuse still blows, then yeah, sounds like a short to ground somewhere. If not, start putting bulbs back in until the fuse blows; at whatever point it does, that bulb base/socket may be the location of the problem.
Old Aug 29, 2009 | 11:17 PM
Franklin2's Avatar
Franklin2
Check the added wiring. Sometimes proper care is not taken when routing wires through the sheetmetal.
outflying
Dec 13, 2010 09:26 PM
GloveGuy
Electrical Systems/Wiring
Dec 21, 2007 09:22 AM
mick460
Feb 27, 2004 07:46 PM
barrys00
Feb 16, 2004 09:28 AM
040498
Jul 17, 2002 02:59 PM
