Truck overheating a bit - Timing?
Old Aug 26, 2009 | 10:57 PM
Grizzle33's Avatar
Grizzle33
I've recently done a distributor change and havent got to a timing light yet - I've driven the truck a few times and I've noticed that the temperature gauge is a little bit higher, not in the "Danger" zone but enough to drive me nuts.
Question: Could the timing not being correctly set or the carb not tuned properly cause the truck to run a little hotter?
In my head full of vast knowledge about these trucks (2 months worth ) it seems that it WOULD, but I Just wanted to check.
I did a radiator flush tonight just because it needed it anyways and I was hoping it would fix it, but it didnt.
From what I can gather in my Chilton book the timing should be...6B and idle should be about 550
I'll get that all ironed out tommorow night and see if that helps it.
Thanks in advance!
-Josh
Old Aug 26, 2009 | 11:13 PM
Grizzle33's Avatar
Grizzle33
Wow, just saw that post above this one.
Sorry!
Old Aug 27, 2009 | 08:57 AM
northerndave's Avatar
northerndave
does it start hard when the engine is warm?
like the starter can hardly kick the eingine over?
if so then that's a sure sign you've got it set a little too far before TDC.
Old Aug 27, 2009 | 02:06 PM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt
Former Vendor
Excessive timing advance can cause elevated engine temperatures.
Dan. (Not Ed.)
Old Aug 29, 2009 | 12:37 PM
Grizzle33's Avatar
Grizzle33
Fixed?
I went to see a mechanic buddy lastnight and had the truck timed properly and it didnt fix the temp problem. He told me it was most likely the radiator so we drained it enough to see the fins and some of the fins are clogged, but not all.
I had a hunch it was just the thermostat by now so I went and got one this morning. I didnt know what to put in it since it HAD a 195 in it - I tired a 160 and it fixed the problem.
My only question now is the temp gauge isnt in the middle, it's just before it - is that bad?
Old Aug 30, 2009 | 12:54 AM
Holiver31's Avatar
Holiver31
You need to install a mechanical gauge and get an actual temp. reading. The stock gauges are prone to going wacky, especially after 35+ years. It could also be a bad ground which is causing the temp gauge to fluctuate. Turn the truck on and get it warm then hit the lights and see if it moves the gauge any. Also, putting in a 160 tstat isn't going to help you in the long run. So install a mechanical gauge and post your results.
Old Aug 30, 2009 | 11:51 AM
Danger_Dave's Avatar
Danger_Dave
do you have a fan shroud? i would suggest one, also a better fan
50 Flathead f-2
Modular V10 (6.8l)
Mar 17, 2015 02:27 PM
fbh31118
Nov 5, 2014 07:55 AM
77hiboyboy
Apr 16, 2007 10:44 PM
patriots6800
2004 - 2008 F150
Jul 11, 2005 11:25 AM
BigMattXXL
18
Aug 18, 2003 11:19 AM
