238,000 miles going back to commercial?!?!
Like the title says; I'm considering going back to commercial driving with a pickup and had a few 'out loud' thoughts that I've been kicking around. I've found an opportunity that pays well and leaves the scheduling of home time up to me aka. family friendly.
The truck in question is the one in my garadge photo, it's a 2002 F350 with a 7.3, 4r100, 4x4 and nothing else real out of the ordinary. There is a laundry list of work that needs to be done to make this thing legal and just general up keep items like trans and diff fluid changes shocks and brakes. I don't want to delude my self here because I know it's an older truck. The plan is to just run a few campers and see how it goes, no giant wedge trailers full of cars and vans. I've done that before and it really works a truck over pretty good, that's why travel trailers and the like are a little bit better being designed to be hauled by pickups.
Just to add to the picture a little bit more, the truck has been used commercially before judging by the inspection sticker in the window. I see that some one has changed the alternator, water pump, and possibly the oil lines, lower ball joints and cps. At least judging by the looks of the parts. The motor starts and runs well with only a slight pewf of blue on start up. There also seems to be a little bit of leakage from the rear main seal but not very much. Unfortunately I don't know if the transmission has been rebuilt but if feels firm and the fluid appears normal, seems like it almost would have had to have been after the amount of miles on it.
My question is; What other items should I look at or inspect to make a more informed decision. Most of the other fellas that I drove with were getting between 1/2 and 3/4 of a million miles before they had to look at a serious rebuild but there again that was commercial service and being **** about service. Well, you can see the truck and have a little history what do you think, what would you be looking at? Sorry about the long post. Thanks in advance for all the input!!
It is just broken in... If it has been commercially before and rode hard I would take it in to a GOOD diesel mechanic and have it checked out. May just need fluids changed. If you plan on hauling for a long time you don't need to **** your employer off with breakdowns....
I agree with you %100 and had that on my list too. Does FTE have a thread started of reputable and not so reputable mechanics and dealers? If not and the mods see this thread I'm going to throw it out there as a suggestion.
Repairs and additions with pictures
Just a little update on whats happened so far. Changed the rear end fluid which was a strange redish black color and the rear end cover got a fresh coat of paint. Also, did a little shearchin' at the local junk yard and came up with a set of licence plate lights, the truck was missing both when I picked it up. Got the CB mounted and man does that look slick up overhead like that. With a new pig tail I got rid of that stupid ABS light on the dash, the old one rotted in two, also another $5 junk yard find. Not to mention the dealer wanted to sell me the whole harness just to get the VSS plug. I think not. Fog lights are operational although the passanger side needs to be replaced due to being broke out at the mount.
What do ya think so far. Too many pictures?
I got the idea from F 350-6 on mounting the CB over head know that I go back and look.
My 99 model has 271,000 on the clock and I REALLY use what you can see in my album. So far the engine is bulletproof, although I am not impressed with Ford quality overall. Seems that every week there is something to replace. Coolant tank, water pump, senors here, sensor there, heater core, differential gears.
I keep watching the 1 ton trucks pulling 30,000 goseneck commercially. Just this week spotted 4 of them pulled by Dodges and 2 by Fords. One of them was on the shoulder with hood up.
My F450 doesn't have much competition and the way I converted it - it can do things no other truck can, but would I be on 1 ton market, I would strongly scratch my head.
That's just a mount that I picked up at a truck stop awhile ago. I've mounted attenna's there in the past on several other trucks without a problem.
