Leaking Tranny?
Old Jul 9, 2005 | 01:29 PM
patriots6800's Avatar
patriots6800
Leaking Tranny?
I've noticed this the last two times i've changed my oil and have wondered if anyone else has the same problem. There's a little bit of tranny fluid around the rubber plug on the bottom of my 04 fx4scab. My bronco had this from time to time but i just thought it was cause of its age. My trucks got 11000 miles on it
jeff
Old Jul 9, 2005 | 02:06 PM
pfogle's Avatar
pfogle
The rubber plug? You mean in the dust shield for the torque converter and flywheel? If it's leaking there then you have a front seal leaking. Do you drive it hard? This can cause high heat in the trans, and fluid can be forced out.
Old Jul 11, 2005 | 10:06 AM
piercede's Avatar
piercede
I noticed this on my 05 and my buddies 05 as well. NOt sure if it is a problem or not, since his did it too it didn't concern me too much. Anyone else have this happening? Is it somethign to have looked at?
Old Jul 11, 2005 | 11:25 AM
bdmcdonald's Avatar
bdmcdonald
I have an '04 5.4l and have no leaks at all, anywhere. A leak is a sign of somethong wrong and should be looked at before bigger problems develop. At 11,000 mi you are still under warranty so take it in and get it fixed!
Mowing Man
17
Mar 24, 2013 11:55 AM
the Mad Modder
1983 - 2012 Ranger & B-Series
21
Jun 12, 2008 08:41 PM
Agemenon
Dec 15, 2006 03:14 PM
serving_time
15
Oct 23, 2003 03:57 PM
BGL
1978 - 1996 Big Bronco
13
Sep 24, 2003 11:10 AM
