T/C problems
Old Aug 26, 2009 | 04:15 PM
helirich's Avatar
helirich
T/C problems
I need some info quick.
Ok, I got a 1990 351/E40D. I'm replacing the Torque converter. The guy that sold me one sent the wrong one. Talking to him, he says the one I got is for a deisel or big block. The only differnce is a slightly lower stall and it mounts to the flywheel with six studs instead of four. He will se4nd me the correct one, but it will take a week. My truck is in pieces and I would like to get it done.
My questions:
I can drill six holes in the flywheel. This is no problem. Infact there is a pilot hole at five of the locations allready. The problem is the sixth location has a weight welded over it. I have a mill and can slot the weight, but how critical is that weight to the smoothness of the engine.
Second, Do you guys think a converter for a deisel will be no problem on a small block.
I need answers by tomarrow morning. Thats when he will send out a new converter.
Thanks
Old Aug 27, 2009 | 06:39 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Yes, that weight is critical. If you change it at all you need to rebalance the flex plate back to where it was.
A diesel torque converter is going to have much too low of a stall speed for a 351. The truck will be a dog off the line and you're not going to like it at all.
Old Aug 27, 2009 | 07:54 AM
helirich's Avatar
helirich
Thanks,
Thats what I needed to know. I'm a Mark also. Use to live in central Fl. Panhandle now.
