smoke switch
Old Dec 8, 2009 | 10:31 PM
Jerry-Rigged 6.0's Avatar
Jerry-Rigged 6.0
I have a 6.0 with SCT (Tow, Performance, Insane), egr delete, torque converter, stock straight piped, and Regulated return fuel system. In Insane it smokes only a little, is there a way to get more smoke out of it? not looking for a lot but more. could I adjust the RR fuel system via the regulator? maybe put in a bypass just for "one of those days" ?
Old Dec 8, 2009 | 11:25 PM
ptr34's Avatar
ptr34
have them put more fuel at start.thats what i had elite do for my insane tune but i still like my x race from id better and it smokes more
Old Dec 9, 2009 | 06:14 PM
william_04_x's Avatar
william_04_x
Smoke switches are for posers.. Hook it up, and you're an instant ahole...
Old Apr 13, 2010 | 06:26 PM
AndeyHall's Avatar
AndeyHall
Originally Posted by 04redstroker
My truck bellows smoke and hauls ***. Just wonderin, would this be something good to help with VGT sticking problems, say have the switch hooked up, and flip it on and off to open and close the vanes. Do it every so often and they wont stick, right? Or am i looking at it wrong.lol Not while on the throttle, say maybe at idle? I drive my truck pretty hard, so im not to worried about it, just curious.
If the vanes stick it's because carbon is built up in there and it just absolutely won't move. From what I've been told (and makes sense if you think about it) the only way safely and effectively and cheaply "un-stuck" the vanes is to lay on the throttle from a dead stop until it breaks loose. That's what I did with mine (however when it happened to mine I had no idea about this issue, and knew nothing about the turbos period. I just laid on the throttle because I was pissed off the I had no power). But if anything the switch will only cause more smoking because all that smoke and carbon will run through your turbo and build up on your vaines. NO GOOD!
Froglips
Sep 14, 2008 08:23 PM
steve83
Nov 12, 2002 11:53 PM
buzzard
May 4, 2001 01:36 PM
kioolt
Apr 27, 2001 10:03 PM
mocky
Apr 11, 2000 11:37 PM
