V/B code springs
Old May 25, 2012 | 09:26 PM
Footy's Avatar
Footy
V/B code springs
I have a 2001 4x4 ex with a 7.3. I am hoping to do the super duty spring swap. I have found a set of V code front springs from a 2004 F250 4x4. Does any one know if these will work on my excursion? I had read somewhere to use 1999-2003 model V code springs. Also this guy has some P code rear springs. I assume that I should not buy these P code rear springs since everyone seems to use the B code rears? Any advice is appreciated.
Old May 25, 2012 | 11:37 PM
lovestrucks's Avatar
lovestrucks
I'm pretty sure that you'll be able to use the ones off the 04. I was gonna use some from a friends 04 because he leveled his truck, but he sold them before I really knew about what I needed to look for and they would have worked.
P codes I believe would fit however they are very stiff, and almost everyone is going with B codes, and some I think with C codes.
Old May 26, 2012 | 06:58 AM
bigwhitetruck01's Avatar
bigwhitetruck01
This is what I did.
https://www.ford-trucks.com/forums/1...uspension.html
You may want to consider X-codes for the front, just for the additional lift when compared to the V's, since you have the heavier 7.3. That combo will likely keep the truck as close to level as possible.
pkthomas
Nov 12, 2016 03:41 PM
marshallstanford
Aug 15, 2016 05:43 AM
Traveling4awhile
May 14, 2013 09:10 AM
wildstang
Jun 16, 2012 03:39 PM
MontanaBighorn
Jul 17, 2011 11:12 PM
