Sponsored by: Real Truck
Glow plug problem
Old Aug 24, 2009 | 02:38 PM
99whiteford's Avatar
99whiteford
Glow plug problem
A friend dropped his 99 f-450 off today to have alternator rebuilt.His problem it turns out is not a bad alternator,but the glow plugs are staying on all the time.It is not the solenoid because i can disconnet one of the small wires on the solenoid and they will kick off..where is the glow plug controller on a 7.3 powerstroke or what controls them.
Old Aug 24, 2009 | 03:00 PM
superduty4x4's Avatar
superduty4x4
The relay is what controls the glow plugs, which gets its signal from the PCM. My guess is the relay is sticking on, and when you removed that small wire you removed the ground signal from the PCM that turns the glow plugs on which is why they kicked off. New GPR and you should be set.
markbest
Mar 23, 2014 08:41 PM
86351wHOsupercab
Oct 25, 2013 08:45 PM
99LSxSS
Aug 31, 2013 07:01 AM
travis77365
May 22, 2005 01:50 AM
lou1f
Oct 13, 2002 10:25 PM
