Introduction
Old Aug 25, 2009 | 06:50 PM
  #31
totin_tools's Avatar
totin_tools
Welcome, seems like everyone has you pointed in the right direction.
Old Aug 25, 2009 | 07:10 PM
  #32
SkySkiJason's Avatar
SkySkiJason
Lots of things can make it smoke, many are no big deal. What color smoke and when does it do it? ie, only when floored from a red lite - while idling - only when cold - anytime driving - white, gray or black smoke, etc...
There's lots to learn to check as preventative maintenance, but I always pull the air intake tubing off (7.3's) and inspect tubing for dirt (oil OK, dirt BAD) and look at the turbo wheel. Check the wheel for obvious flaws/wear and try to wiggle the shaft.
Autozone and similar will read codes (not all codes...) for free, but the SES light has to be on when they check it. If you get a chance to have a full computer diagnostic check, you can learn more about intermittent issues as well as testing individual injectors, etc.
Like the others said, welcome and please come here for solid advice before spending $$ on your new baby.
Old Aug 25, 2009 | 08:39 PM
  #33
BobbyDiesel71's Avatar
BobbyDiesel71
Our 7.3 engnes pretty much will run on any quality Diesel oil.
Many,including myself, run Shell Rotella T, either 15W-40 or 5W-40 syn
Both are available at Wally world and the motorcraft FL-1995 oil filter is $10.00
dino oil is like $11.00 or so per gallon and the syn is $20 per gallon
Others run Schaffers, MOBIL DELVAC,Royal Purple or Amsoil
Old Aug 26, 2009 | 12:06 AM
  #34
NorskeMann82's Avatar
NorskeMann82
Thanks for all the tips. I climbed on top of the motor and sure enough there is a pool of oil between the heads. The O-ring mentioned, is that going to be on the oil reservoir? I haven't really had a chance to tear into it yet, but I have done some looking and bought a Haynes repair manual. I will be off tomorrow, but I will need to have it ack in working order by Thuresday night so I can go back to work. I will try to clean the sensor and see if that helps me get one less light shining on the dash.
Jetmech6
1978 - 1996 Big Bronco
Oct 26, 2014 04:13 PM
Randall Miller
Engine Swaps
Feb 25, 2004 02:56 PM
randallc
Paint & Bodywork
Jun 28, 2003 07:53 PM
randallc
Jan 11, 2003 04:35 PM
block0
Nov 29, 2000 12:18 PM
