Introduction
Old Aug 25, 2009 | 01:20 AM
NorskeMann82's Avatar
NorskeMann82
I think the Autozone I pass by still does that for free, so I will see if they can get anything. I really hope is a cheap (or free) and easy fix.
Old Aug 25, 2009 | 01:31 AM
Tenn01PSD350's Avatar
Tenn01PSD350
Most discount auto parts stores cannot pull diesel codes. Be prepared for that. They may even pretend to pull codes and give you the wrong info.
Old Aug 25, 2009 | 01:34 AM
NorskeMann82
Good to know. I appreciate the heads up. I also pass by a Ford dealer, so I'll check them out.
Old Aug 25, 2009 | 01:35 AM
4inchlovin's Avatar
4inchlovin
As mike said, Auto parts stores usually dont have the right equipment to pull codes from a PSD. And they generally dont like to admit that. I can think of a few threads where guys were chasing problems that didnt exist because of false info.
Where in the middle of OK are ya?
Old Aug 25, 2009 | 01:57 AM
NorskeMann82
I'm right between Meeker, OK and Prague, OK. Anyone have any suggestions on where I can get the codes read correctly?
Old Aug 25, 2009 | 02:20 AM
ccg711's Avatar
ccg711
if your cruise stopped working and the abs light comes one, I would starting by cleaning/replacing the rear ABS sensor located on top of the differential. It's a one bolt affair. As for the SES light, get a code scanner, and don't use the free scan service at the parts stores. Their scanners don't work on PSD's since the computers aren't fully OBD-II compliant. Find someone with a good scanner. If you want to purchase one check out auto enginuity with the ford expansion pack, little pricey to start, but well worth the money.
Old Aug 25, 2009 | 09:21 AM
indyF-350psd's Avatar
indyF-350psd
you can't fix stupid!
thats what i was thinking except its called the vehicle speed sensor (VSS) not an ABS sensor. just want to make sure he asks for the right thing...........
Old Aug 25, 2009 | 09:32 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Bill, NAPA call the VSS a ABS sensor. He needs to ask for the ABS sensor at the parts store.
Old Aug 25, 2009 | 10:03 AM
SpringerPop's Avatar
SpringerPop
And, indeed, it IS the sensor for the rear ABS. That's in addition to the other job it performs.
Pop
Old Aug 25, 2009 | 10:28 AM
Bigcat350's Avatar
Bigcat350
Welcome to FTE Randall.
Old Aug 25, 2009 | 01:18 PM
PaysonPSD's Avatar
PaysonPSD
Nice to have you aboard Randall. Check out these two links. Some great info on Maintenace, Mods, Etc...
RHN Guides, Maint. & Mods
Guzzle's Web Pages
Old Aug 25, 2009 | 01:30 PM
D ROUSH's Avatar
D ROUSH
Welcome.. I too am very new but the site sure has alot to offer and a truck load of friendly advice and opinions. D8chumley might be a character to harrass.
Old Aug 25, 2009 | 01:31 PM
  #28
indyF-350psd
Pop
ah! thanks for clearing that up. my mistake!
Old Aug 25, 2009 | 02:06 PM
  #29
61 uni's Avatar
61 uni
Welcome Randal. I bought my truck from the origional owner who managed a Ford service department. They used motorcraft oil. I changed to Rotella and the engine seems happier.
Old Aug 25, 2009 | 05:04 PM
  #30
4inchlovin's Avatar
4inchlovin
Where are you located???? We have good bunch of central cali guys...
