Rear view mirror ??
Old Aug 23, 2009 | 05:33 PM
Big_Al59's Avatar
Big_Al59
Rear view mirror ??
My rear view mirror fell off yesterday, I bought some glue at napa to put it back up. Does the little metal plate that attaches to the window come out of the plastic piece on the end off the mirror stem? I tried prying and gently tapping but it wouldn't budge. Anyone been thru this? I hate to break the plastic and have to buy a whole new mirror assembly. Thanks
Old Aug 23, 2009 | 05:52 PM
danr1's Avatar
danr1
Should have a little allen? set screw holding the metal plate into the bracket. Back the set screw off a little and slide the plate out.
Old Aug 23, 2009 | 10:19 PM
EPNCSU2006's Avatar
EPNCSU2006
Some of the newer ones snap in place with no set screw. There was a thread about this maybe a couple of months ago about this very thing. If you can find it, it should answer your question.
Old Aug 24, 2009 | 04:03 AM
LCAM-01XA's Avatar
LCAM-01XA
My rearview mirror fell off my windshield about an year ago - I think that was the single most useful mod done to this truck!
Old Aug 24, 2009 | 10:19 AM
Big_Al59's Avatar
Big_Al59
I'm still working on it. Looked for a set screw but didn't see any, however there is a small opening on the one end that I can't see to the bottom. Might try a couple different allen wrenches and see if one will work.
I do like the improved forward visibility, except I miss it when towing my utility trailer. Like to be able to keep an eye on things in the trailer, make sure nothing is coming loose or threatening to blow out of the trailer.
Old Aug 24, 2009 | 11:18 AM
quicklook2's Avatar
quicklook2
no set screw.
small screwdriver will get it apart.
this was covered before so do search for more info.
Old Aug 24, 2009 | 11:28 AM
danr1's Avatar
danr1
Yea gotta be the snap on type, if it had a set screw you'd have see it with another once over had you missed it the first time. Reason for the question mark in my OP here.
Fordmaster06
May 28, 2012 06:27 AM
dave3406
Apr 15, 2011 02:52 PM
Ethan89
Jan 1, 2009 11:40 AM
Icefan71
Oct 30, 2006 10:04 PM
rfrench1
1983 - 2012 Ranger & B-Series
Jul 26, 2004 08:59 PM
