distributor / timing
Old Aug 22, 2009 | 08:36 PM
0351mike's Avatar
0351mike
I was working on my 79 shortbed 4x4 and went to replace the distributor. It was the last thing on the truck not refurbed or new. I had bought the motor assembled by someone else with a few hundred miles on it a few years back, 400m. I was carefull in pulling the distributor out , but still managed to pull the oil pump drive shaft lose. All I can think of is that the metal ring that supposed to stop this from happening was not there. So after I dropped the pan and re positioned the drive shaft the distributor dropped in. It was close to where I had marked it, but could have been a tooth off. The truck fired right up. When I went to put the timing light on it- the marks are about directly on the bottom of the balancer- not up at the timing piointer. Seeing how the truck runs good and I had timed by ear- will this affect anything- is the cause that I am a tooth off? I really dont want to pull the distributor back out. Please let me know what you think?
Old Aug 22, 2009 | 08:55 PM
montana_highboy's Avatar
montana_highboy
Where are you timing wise? 6,8,10 BTDC?
Old Aug 22, 2009 | 10:52 PM
Furyus1's Avatar
Furyus1
If you do wind up pulling the distributor back out and that shaft comes out again - it's possible to drop it back in place with a magnet and some patience - I have a pretty powerful little magnet on the end of a pick-up tool I used to lower the shaft down into the hole then I used a street-sweeper bristle to guide the lower end into the oil pump - once it's in place, you can use a socket (I forget what size) on an extension to turn the shaft to make sure it's seated and turning the pump...
After I initially pulled the shaft out, I didn't seem to have any problems with it afterward and I had to pull and reposition the distributor a few times before I got it right...
Just a thought...
Old Aug 23, 2009 | 06:39 AM
0351mike's Avatar
0351mike
Thanks, I hope not to go through that again, but will give it a try if I need to. As far as timing- I have always heard that once you put an aftermarket cam in, you use the marks just to get in in the ball park. I have no idea what the specs are on the cam, or if it has been advanced off the timing gear. Would it be smart to start all over again- pull the distributor out and start at TDC on the number 1 cyclinder?
BaronVonAutomatc
Nov 22, 2010 02:39 PM
ErrorS
Nov 7, 2007 07:04 AM
bourbon
Mar 15, 2005 01:42 PM
'73 250
Feb 16, 2005 11:28 PM
LeatherNuts
Dec 9, 2004 11:38 AM
