Fuel Pump Dead
Old Aug 23, 2009 | 11:27 AM
jeff7825's Avatar
jeff7825
Originally Posted by Orezona
Yes.
"NOTE: FueLab pumps require a MINIMUM fuel feed line size of 5/8". Use of a large diameter fuel tank pickup (like our 5/8" Pickup Kit) and appropriately sized fuel line HIGHLY RECOMMENDED. Improper fuel line size can lead to pump damage and is not covered by the FueLab Limited Warranty."
That's what I thought. The Fuel Lab seems to be the way to go, but it seems like you would have to drop the tank again to put in the new 5/8" pickup and then get new fittings for your pre pump filter and then the 5/8" line. Or that's what I would have to do on my setup, not sure what kind of setup you have.
<input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
Old Aug 23, 2009 | 07:00 PM
Orezona's Avatar
Orezona
Clay is hooking me up with the Bosch. Should have it Wed. Couldn't pass up the price and top notched service.
Old Aug 23, 2009 | 08:50 PM
indyF-350psd's Avatar
indyF-350psd
you can't fix stupid!
what did you end up getting it for and how did he say it would compare to the stock pump? im looking to get one for the "in case" mine goes out...........
Old Aug 23, 2009 | 09:34 PM
Kwikkordead's Avatar
Kwikkordead
Ford pump ^ ............... ^ Bosch pump.
Notice that the Bosch pump is physically larger and has a much larger inlet as well.
Old Aug 31, 2009 | 07:36 PM
Orezona's Avatar
Orezona
Just wanted to say Clay is top notched fo sho. At absolutely no fault of Clay's, someone dropped the wrong pump in the correct box. So, I got the wrong pump. Clay was all over it from the start. All the way to calling me within minutes of me installing the correct pump this evening. Dude was soo on it, I didn't even have a chance to call him to say I received the correct pump and truck was running great before my cell was ringing with Clay asking if everything was cool. Did I mention Clay was all over this from the start?
I have more to follow up on Dan's pic above and a part number discussion. I just don't have time right now.
See Sig. Riffraff Diesel Performance added.
Old Sep 2, 2009 | 02:30 PM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt
Former Vendor
wow, Clay usually suffers from A.D.D
good job Clay.
lol
Ed
pcpotter1023
Aug 29, 2016 10:47 AM
99 f150
6.7L Power Stroke Diesel
Aug 27, 2016 11:18 AM
NoahandDad
Jul 15, 2016 07:07 PM
HawaiianPSD
15
Jun 6, 2016 12:55 PM
94f250veguy
Jan 10, 2011 04:35 PM
