Hi Guys, Just installed an OEM radio/cd unit in my 07 XL.This radio obviously came out of an XLT which has the connector on the upper dash tray for an auxiliary input such as an MP3 player..The XL version of the f-150 didnt come with that little jack in the dash tray(or the wire from the radio)...anyway Im sure there is a connector on the back of the OEM unit that this input would hook up to,and either need the harness,or a Ford part number so I can order it.
Someone on this site suggestde alldata,and while im sure I could find the actual pin-out on that site,its a subscription site,and dont think this situation warrants it. Suggestions welcome.
sounds like a dumb question, but was there a headphone type jack on the back of the head unit? If there is, you might be able to just plug in a 2.5mm stereo to 2.5mm stereo wire.
Don't know the back of your radio though.....
This is NOT a dumb question...I looked,and didnt see one. There are three connectors on the back,one is the main connector,and two additional ones. Im assuming that the AUX input goes to one of the other connectors.
I hope someone out there found a solution to this. I just bought a shaker 500 for the mp3 capabilities but cannot fiind a plug in. I assume that I am missing the harness that plugs into the back of stereo for a headphone jack of a mp3 to plug into. Can anybody help with this. Thanks in advacnce.
