Looked like an 088 ATS turbo.
Saw the air cleaner, intake snail, turbo pedistal and turbo, but I never saw any exhaust plumbing.
You need the pipes from the manifolds up to the turbo and from the turbo back down to the exhaust system.
i just grabbed the turbo and what i could only had 45 mins before they closed, and i have to work 2morrow so i couldn't be there to take it off. i figure if i get the turbo then maybe the rest will be left for when i can get there, or so i hope. haha
that sounds like a very reasonable price for an ATS turbo. I don't think you can go wrong. Now go to bed early, call in sick, whatever and get the rest of those little parts that you need. Those are the ones that add up quickly! take care.
FINALLY got the down pipe and cast y pipe, also should i grab the valve cover with the cdr on it? or can i just attach it to the ats air filter box? i got 2 free gauges 1. autometer boost gauge, and 1 isspro pyro. there a little messed up check out my vid and tell me what you guys think of using these gauges.
ps turn your volume down haha. http://www.youtube.com/watch?v=bX_L6-rLvS8
Actually, the ATS 088 uses the same grommit as the CDR. Don't know why they went and complicated things with the 093 and used a custom grommit but they did.
Only problem I found is the area around there gets so hot because of the turbo that the grommit gets hard fairly quickly and starts slowly leaking. In my case it manifests itself as a smell of oil in the cab when idling in traffic. Thinking of looking for some big fat custom viton O ring instead, but who has the time for that....
But if its still good, get the grommig anyway. Always comes in handy to have a replacement.
