fuel gauge problem
Old Aug 20, 2009 | 11:04 PM
Sgt. G's Avatar
Sgt. G
fuel gauge problem
hey guys i got a 2000 ford excursion with a wierd problem. my fuel gauge is reading below empty completely bottomed out. and the overhead gauge tells me 0 miles to empty but the tank is near full!!! i keep putting gas in and the gauge dosent move any ideas on what may be wrong?
Old Aug 20, 2009 | 11:41 PM
UrbanXX's Avatar
UrbanXX
First let me welcome you to the forum, Welcome!
It souds as though the float is stuck. Try filling the tank about 1/2 if you have an idea how much fuel is in it. Maybe if the float is stuck the fuel will move around to unstick the float.
I have an 03 and my over-head console stated acting up when I blew the fuse to the cigarette lighter. Check the fuse there. Actually check all fuses.
Then there is always a chance of a loose or broken wire between the tank and the gauge or even the gauge its-self.
Just start the process of elemination.
Old Aug 25, 2009 | 07:58 PM
azcactus's Avatar
azcactus
The fuel guage in my 2000 v-10 failed a while back, so I drove without one, only to have the fuel pump fail a few weeks later.
I agree with UrbanXX- check all the fuses first, even a seemingly unrelated fuse can have weird effects. I found it impossible to get to the sending unit wiring unless you drop the tank- and it's a BIG tank...
Old Aug 26, 2009 | 04:43 PM
hvacguy's Avatar
hvacguy
If your fuses are good, it sounds as though the sending unit has failed.
FastEddie_1
Jul 18, 2021 07:40 AM
jdemkowicz
Aug 9, 2016 12:01 PM
JD_F100
26
Aug 31, 2014 10:26 AM
90'F150
Jun 12, 2013 09:16 PM
navigatorstang
May 15, 2011 03:08 PM
