Fuel gauge
Old Apr 29, 2013 | 04:31 PM
90'F150's Avatar
90'F150
Fuel gauge
Ok so my trucks got the 2 tanks and when it's on the rear tank the gauge works fine but if I put it to the front tank it doesn't work and jut reads empty. Any ideas? Anyone else experience this problem?
Old Apr 29, 2013 | 04:51 PM
Hutch17's Avatar
Hutch17
I had this problem on my 91 250. I dropped the tank and replaced the sending unit float. They get pinholes and fill up with fuel over time. I have an extra I could send you for the price of shipping. It could also be the sending unit and pump are shot.
Old Apr 29, 2013 | 04:53 PM
Big_Al59's Avatar
Big_Al59
Mine started doing that a couple months ago, haven't gotten around to fixing it yet. With my luck
It won't be an easy fkx.
Old Apr 30, 2013 | 02:34 AM
gen.idiocy's Avatar
gen.idiocy
mine reads full till i get to about 1/4 tank than goes back and forth for a bit and than sits on empty any ideas as to what is causing this? i have the dual tank setup and it does it front and rear
Old Apr 30, 2013 | 05:22 AM
Hutch17's Avatar
Hutch17
It's mostlikey the fuel splashing around in the tanks, causing the gauge to fluctuate.
Old Apr 30, 2013 | 06:00 AM
90'F150's Avatar
90'F150
I thought it was the sending unit to but haven't been able to drop the tank yet so I won't know for sure.
Old Apr 30, 2013 | 06:16 AM
Hutch17's Avatar
Hutch17
Dropping the tank isn't that bad. Just soak the bolts in a penetrating lube of your choice. If that dosent work just pick up some new straps and cut the old ones. That's what I did. Also be careful when you take it down and the filler hose is attached, I cut mine because I didn't have the patience to work at it. When I put it back on I had to stretch the hose, so make sure you take your time.
Old Jun 12, 2013 | 09:16 PM
90'F150's Avatar
90'F150
I'm not on to often so I'm just getting to all this now still haven't dropped the tank but am slowly getting to that I'm just running it dry first since gas is about 6lbs a gallon I want as little in there as possible. Say it is the sending unit any recommendations for a certain brand of parts?
Hamberger
Oct 3, 2019 02:51 PM
ms1780
Aug 6, 2007 03:31 PM
DavidHenshaw
Jul 11, 2006 06:47 AM
samfissure
May 5, 2004 12:32 AM
Rbuller24
15
Jun 11, 2003 06:29 PM
