95 Remote Ignition Modules
Old Aug 20, 2009 | 08:27 PM
rainbowATF's Avatar
rainbowATF
Remote mounted Ignition Modules 1994-1996.
Various threads here have discussed previously the ignition modules being sold for 94-96 F150s and related trucks. I do not wish to start another debate about aftermarket parts or what is being sold. I only wish to share my experience and solution, and if it helps you that's great.
I bought a remote ignition module for my 1995 F150 with 5.0L from Advance Auto. They have been great to me. I thought with them selling Borg Warner parts now that I would get the correct module. It was a BWD CBE33. This translate to a Motorcraft DY1075. It ran my truck, caused no CEL. But a scan of the computer showed a DTC of 221. In other threads it stated as DTC 226. This is a loss or missing IDM signal, a difference of pin 4 on module. And this causes an inability of ECU to control timing and default to 10* BTDC. I returned it. Diagrams of the circuits for these modules and more discussion can be found with a search. I soon realized that it didn't matter where I went, I was going to get a Motorcraft DY1075, or its cross referenced part in BWD, AC Delco, Delphi, Airtex, etc. The applications guides all said 90-96 use same remote module.
I entered an order to Ed Olson, Parts Manager, PartsGuyEd.com at Millenium Ford in Seattle, WA. I had previously bought a Motorcraft EGR and a VSS from him. He went out of his way to research this Ignition Module and reassure me that I would get the correct part. We had several phone calls. I sent pictures and the PN on my module. My original was a Motorcraft black module with PN F1SF-12A297-C1A. This was re-engineered and updated to PN 5U2Z-12A297-D in Ford documentation and this translated to a Motorcraft DY1077 which isn't listed for a F150 with 5.0L; even in the latest Motorcraft catalog on-line. I installed the part today, it started; ran it through warmup cycle, drove and no codes only the good 111. If you try to buy a DY1077 or equivalent PN at an auto store local or net, it wouldn't be listed for an 94-96 F150. A BWD is cross reference to their CBE40, but listed as not applicable. Many on-line stores use generic photos; which only cause more confusion.
Many thanks to one of our vendors, PartsGuyEd, Ed Olson, for exceeding my expectations. I got the part I needed and at a great price. I hope this helps someone else here get the correct module; unless you run a scan of your ECU you won't know that you don't have the correct one; the public info on these modules is misleading. I put a couple of pix of the modules in my gallery.
Old Aug 24, 2009 | 01:02 PM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt
Former Vendor
brownie points for me! brownie points for me!
you are welcome, and thanks for the kind words.
Ed
Old Aug 25, 2009 | 05:50 AM
TexasGuy001's Avatar
TexasGuy001
Thats good information to know. I'm glad you mentioned it.
Mookie's 85
31
Jan 6, 2021 11:58 AM
daveengelson
15
Nov 18, 2016 08:36 AM
annaleigh
Apr 25, 2015 08:57 PM
aar_man
18
May 31, 2014 01:30 PM
tpolley
May 11, 2009 10:29 PM
