150 302 help?
Old Aug 24, 2009 | 06:47 AM
150jason's Avatar
150jason
150 302 help?
just put new magnaflo on and changed filter to cone, what can I do to spin some rubber with this thing?
Old Aug 24, 2009 | 07:06 AM
lew52's Avatar
lew52
Depends on what size truck it is 4X4 & so on , what year ,to make the truck run better you might try bumping up the timing to 12-14 before , long tube headers help alot , better heads , gearing ....Lew
Old Aug 24, 2009 | 07:49 AM
150jason's Avatar
150jason
I got a 4x4 f-150 short box
Its got duel tanks as well
I am also looking to improve fuel economy. In a truck like mine is this possible??
Old Aug 24, 2009 | 09:05 AM
lew52's Avatar
lew52
Good its a 150 shorty so the 302 will work well , just keep it geared to the tire size, don't know much about fuel economy but i think long tube headers & a good exhaust will help in both areas ,,, Lew
Old Aug 25, 2009 | 05:53 AM
TexasGuy001's Avatar
TexasGuy001
Well to be honest your probably better off with the stock air box and a I6/460 tube or just the stock tube than you are with the cone filter. I would do that and get a replecement high flow filter. The open element cone filter just sucks in hot underhood air.
I had the KN FIPK on mine for a while and all it did was waste fuel. Also, when it was hot outside and my truck was warmed up it felt sluggish.
If you want it get up and go change the gears to 3.73-4.10. What gears does it have now? This is probably the single most overlooked thing by most people.
What size tires are you going to run?
chris69
17
Dec 16, 2003 10:30 AM
billman
Jan 16, 2003 04:30 PM
2004 - 2008 F150
61
Jan 15, 2003 03:03 PM
michaelskerrett
Jan 13, 2003 09:51 PM
whomrig
Jun 29, 2001 03:03 PM
