Completed frame pics....A Question??
Old Aug 20, 2009 | 11:41 PM
shanes66charger's Avatar
shanes66charger
Originally Posted by lostinfords
strange mounting place for the fuel tank selector valve, mine is mounted fwd. of the fwd. tank, looks really good, what did you do...paint it or rust proof it? how were the frame saver washers to put in? or did you make your own up?
sorry, what are you referring too?
Old Aug 21, 2009 | 12:15 AM
RichS2659's Avatar
RichS2659
What is the JD sitting next to the frame? It looks like a D or R type wheatland tractor.
Old Aug 21, 2009 | 12:18 AM
shanes66charger
1950 JD model R
Old Aug 21, 2009 | 05:33 PM
Jermafenser's Avatar
Jermafenser
Originally Posted by shanes66charger
As for the cables......thanks. It appears there are just springs that hold the cables to the upper shock mounts??
Yes. It's to keep from the cables hanging too low. Nothing special. They are often rusted/thrown away.
Might ask NumberDummy about it - I'm not able to look it up 2A709. I'm guessing an error/omission.
Old Aug 21, 2009 | 05:48 PM
lostinfords's Avatar
lostinfords
I was referring to the p/s pic, front cab mount it looks like you repaired the body bushing mount area on the cab frame mount...I was wondering if you used the frame saver washer that are for sale from broncograveyard or did you repair it yourself, either way that frame looks real good.
Old Aug 21, 2009 | 09:04 PM
shanes66charger
funny story, well not really! The ONLY day I had use of the trailer, I forgot to fix that mount, and as I was strapping it down I was DAMN! I found a washer that is very close to size, and welded it over the top, Not ideal at all. Anywho, I figure ill die grind the hole to size once I get the new mounts. As for the washer being on top, Worst case I'll have to shim the other side, and maybe the rad support as well.....not a big deal!
Thanks alot jermafenser for looking that stuff up. I'll ask ND, otherwise I should be able to find some springs that will work.
thanks again man!
shanes66charger
81
May 25, 2016 02:49 PM
neilc88
Mar 14, 2012 02:18 PM
neilc88
Electrical Systems/Wiring
Mar 14, 2012 10:38 AM
midcal48
Feb 12, 2011 10:43 PM
shanes66charger
Mar 19, 2009 09:57 PM
