Y-block trans adapter
Old Feb 6, 2011 | 04:44 PM
midcal48's Avatar
midcal48
I bought what i think is a 292 Y block and a sm420 granny 4 speed trans. My question is if that is some sort of adapter that mates the 292 to the 4 speed, and if it is an adapter can any other trans be used with that adapter? Thanks
<a href="http://s168.photobucket.com/albums/u197/CaliLowLife/?action=view&amp;current=DSC02089.jpg" target="_blank"><img src="http://i168.photobucket.com/albums/u197/CaliLowLife/DSC02089.jpg" border="0" alt="Photobucket"></a>
<a href="http://s168.photobucket.com/albums/u197/CaliLowLife/?action=view&amp;current=DSC02086.jpg" target="_blank"><img src="http://i168.photobucket.com/albums/u197/CaliLowLife/DSC02086.jpg" border="0" alt="Photobucket"></a>
Old Feb 6, 2011 | 05:23 PM
85e150's Avatar
85e150
"I bought what i think is a 292 Y block and a sm420 granny 4 speed trans. My question is if that is some sort of adapter that mates the 292 to the 4 speed, and if it is an adapter can any other trans be used with that adapter?"
The answer would seem to be "Yes".
And those transmissions would be, to quote from the following link:
"The front bolt pattern is the consistent GM Muncie / Saginaw four-bolt pattern as found on GM bellhousings and transmissions from the 1940's through the 1990's..........."
The GM Muncie SM420 Transmission - Novak Conversions
That's a powerful strange looking set up there. Are there any names/numbers etc on the casting part, or the red part?
How does the clutch work in that thing?
Old Feb 6, 2011 | 05:44 PM
312's Avatar
312
it looks like the adapter to mount a flathead trans to a y block.
Old Feb 6, 2011 | 06:10 PM
midcal48's Avatar
midcal48
Thanks for the reply.
The numbers on the drivers side of the trans are
W G CO
T 8 D-1A
And on the passenger side is
59T-7006
N 10
The guy i got the setup form said that clutch is that oval shaped piece with the hole in it on the drivers side of the trans.
Old Feb 6, 2011 | 09:12 PM
85e150's Avatar
85e150
OK, so now I see that, and I look at the pic of the SM420.
That is not a SM420.
--no PTO is the clue from a distance.
--it's markings tell the tale up close.
W G Co. = Warner Gear Company.
T 8 D 1
Possibly the auxillary trans from 1928 AA trucks.
aa-fords.com &bull; View topic - Warner Gear and the T81
Here is a T7A1, looks related:
WARNER GEAR CO. T7A-1, WARNER GEAR CO. T7A-1 Torque Converter & Transmission for sale, Used WARNER GEAR CO. T7A-1 Torque Converters & Transmissions at Tradequip.com
More on the T8 and T9:
Untitled Document
A real Annntick if you ask me.
Old Feb 7, 2011 | 06:44 PM
midcal48's Avatar
midcal48
thanks for all the help, and there actually is a pto on the passenger side.
I was also told on another forum that it is not a sm420 but either a Warner T-9 or T-98.
Old Feb 8, 2011 | 09:46 PM
ibuzzard's Avatar
ibuzzard
See A Man About A Horse
You can rule out the T-98,I have one and your photo doesn't vaguely resemble it.I'm interested in the i.d.,hope someone can recognize it.
Old Feb 11, 2011 | 08:48 AM
bigwin56f100's Avatar
bigwin56f100
I believe thats a clark 5 speed. But the question is, is it a direct drive 5 speed or an overdrive 5 speed.
Old Feb 12, 2011 | 10:43 PM
85e150's Avatar
85e150
If it's a Clark, why does it have "WG" cast into it, and T1?
This is said to be a Clark 280v. Blow up the pic and see if you can read the numbers on the side. Or, better yet, find a good Clark image so the OP can compare his trans to a Clark.
http://www.google.com/imgres?imgurl=...0&tx=101&ty=76
Another one:
http://www.google.com/imgres?imgurl=...w=1276&bih=548
shanes66charger
81
May 25, 2016 02:49 PM
Highboy74
16
Jul 24, 2012 09:53 PM
Highboy74
Apr 16, 2012 09:04 PM
Lil Red Sled
48
Dec 14, 2011 11:36 PM
rotun
May 7, 2010 09:31 AM
