Coolant weep
Old Aug 19, 2009 | 03:50 PM
Ratkat's Avatar
Ratkat
Coolant weep
I have a coolant weep there is drain holes on either side in the middle of the heads this is where I can see a coolant mark on both sides. Has anyone had this before and or any thoughts on where it may be coming from ?
Old Aug 19, 2009 | 04:05 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Maybe the fan is blowing coolent from a leaking hose or stat housing? Never heard of this from the middle of the heads. Is it in the valley or the side of the heads?
Old Aug 19, 2009 | 04:08 PM
Ratkat's Avatar
Ratkat
On the outside of the heads like it has come out of the drain holes
Old Aug 19, 2009 | 04:09 PM
FordTruckNoob's Avatar
FordTruckNoob
Can you take a picture?
Old Aug 19, 2009 | 04:12 PM
Ratkat's Avatar
Ratkat
Its a PITA & I'm hopless at posting them. The weep is just underneath the ex manifolds there is a little round drain hole in the middle of the head
Old Aug 19, 2009 | 04:18 PM
rbaker6336's Avatar
rbaker6336
by any chance an expansion plug?
Old Aug 19, 2009 | 04:28 PM
miller_feed
I had a simular issue once before. There was a plug that was leaking on the back side, the side close to the firewall in back of the engine. I remember I had to use a 1/4" (I think) ratchet to tighten the plug, because it was a square drive. I don't know if this is the same thing or not.
Old Aug 19, 2009 | 04:29 PM
Ratkat's Avatar
Ratkat
Hmmm looks like a drain hole will have to inspect further
Old Aug 19, 2009 | 04:44 PM
big poppa's Avatar
big poppa
Sure you ain't talking about your freeze plugs, I had one leak on mine at under 20,000. Seen you post Ray, I think we're thinking of the same thing.
Old Aug 19, 2009 | 04:51 PM
Ratkat's Avatar
Ratkat
I thought freeze plugs would be in the block not the head
Old Aug 19, 2009 | 05:00 PM
FordTruckNoob
Hmm, I know there's one in the block around there from when I had to flush the cooling system. Are you sure it's in the head?
Old Aug 19, 2009 | 05:06 PM
big poppa's Avatar
big poppa
We got to learn yaa how to post pics, that would clear everything up. Those coolant plugs(for draining) are up near those freeze plugs on the block, if I remember correctly. Subscribing.
jbrittonjr
Flathead V8 & Flathead 6
Jun 17, 2021 12:57 PM
Shawn MacAnanny
Jan 30, 2016 06:39 PM
burtpolson
Jan 28, 2016 08:55 AM
Mikeman
Nov 9, 2013 11:08 PM
pensacolaexplorer
Oct 26, 2007 10:01 PM
