coolant weeping from timing chain cover
we have a 97 Explorer 4.0L motor without the SOHC
A small amont of coolant is leaking from the timing chain cover gasket area on the drivers side.
Do I need to replace the timing chain cover gasket only? Other things that will cause coolant to weep out of the side of the timing chain cover when hot or I do a pressure test?
The radiator and water pump are fairly new. Explorer has about 115K miles.
Tips? Tricks? Wisdom?
Thanks,
pensacolaexplorer
Thanks,
pensacolaexplorer
LeoJr
02-13-2018 10:32 PM
Mikedibenedetto
05-29-2017 10:31 PM
Shawn MacAnanny
01-30-2016 06:39 PM
GuitarJesus
11-28-2015 03:14 PM
