Rebuilt carb , no improvement?????
Old Jan 15, 2003 | 02:17 PM
Farmers Ford's Avatar
Farmers Ford
I have an 84 F250 with a 351 and the C6 tranny,about a week ago I had the 2bbl. carb rebuilt by a mechanic, and the idle is better, but when its drivin it will bog and try to stall.
could it be the carb, the fuel pump, a vacum leak>???
I'm at my wits end .
Old Jan 15, 2003 | 02:49 PM
gasman6674's Avatar
gasman6674
Old Jan 21, 2003 | 02:35 PM
xuare's Avatar
xuare
You may want to make sure your accelerator pump is working and the nozzles aren't clogged. If they are your engine won't accellerate (may even die) if you stomp on the gas too much. It would still work under light acceleration.
My 351 also does this if it's eaten too much oil and needs more to raise the level.
Old Jan 21, 2003 | 10:20 PM
Mike W's Avatar
Mike W
90% of carburator problems are caused by the ignition system.
thunderbolt427
2009 - 2014 F150
Jan 19, 2017 05:44 AM
az28
Modular V8 (4.6L, 5.4L)
Jul 31, 2016 09:05 PM
hillbillydad
Offroad & 4x4
16
Apr 18, 2004 03:47 PM
ctfuzzy
15
Nov 10, 2003 01:51 AM
enfer_know
Bronco II
Apr 23, 2002 08:18 AM
