Offroad & 4x4
snorkel ideas?
Old Apr 14, 2004 | 09:24 PM
hillbillydad's Avatar
hillbillydad
Question snorkel ideas?
i was wonderign what kidna snorkel ideas you guys might have?
Old Apr 14, 2004 | 09:31 PM
nick88f150's Avatar
nick88f150
i'd say get some flex like vacuum type tubing, fiond a size that'll fit your intake, vent it out the side, and get a peice of rigid, or keep the flex, and run it up the side. then take a round filter and fit it on top of the tube. thats my idea, never done it tho, just deamt it up now
Old Apr 14, 2004 | 09:37 PM
Idiomaticman's Avatar
Idiomaticman
here, this works great....and guess what.....its a real snorkel
Pics One
More Pics
thats what i would do, it looks good and is very functional....although it is spendy.
Idio
Old Apr 14, 2004 | 09:40 PM
hillbillydad
were do you get a snorkel like that?
Old Apr 14, 2004 | 09:52 PM
Idiomaticman
its from a landrover dicovery, the second link even gives the parts number for it, they are about 300$ for the kit, then you have to mod it to fit the air box, but you have to admit, it sure looks bad *** on a for huh?
Idio
Old Apr 15, 2004 | 10:07 AM
hillbillydad
yea it looks good, but to pricy for me.
Old Apr 15, 2004 | 10:10 AM
fishmanndotcom's Avatar
fishmanndotcom
tupperware cake box, elephant trunk drain pipe, and a few tubes of silicone!
mine is coming in the near future.
or you could route some pvc pipe from the engine cmpt into the cab but that's a lot more permanent!
could also try dryer hose
or what about flexible exhaust pipe?
i dunno just throwing ideas out on the table
although i know the cake box works...i have seen it done. if i can get a pic of it i will.
-jason-
Old Apr 15, 2004 | 03:34 PM
Texan1983's Avatar
Texan1983
the outside part is easy, so good old pvc pipe and run it where ever you want. the hard part about the older carb. trucks it how to make an air box for your pipe to fit on. anyone got any ideas? like maybe old mustang ram air system modifide to fit on your truck? whats this cake box thing your talking about fish?
Old Apr 15, 2004 | 04:16 PM
fishmanndotcom
ok take a round plastic tupperware cake box and cut a hole on the top or bottom (doesnt matter) the size of the top of your carb....then on the other side cut another hole the size of your pipe (w/e you use) and caulk/silicone the crap outta it! then just run the pipe into your cab.....voila! snorkel for a couple of bucks at the Dollar Tree.
-jason-
Old Apr 15, 2004 | 04:33 PM
F-750pickup's Avatar
F-750pickup
3" pvc or exhaust tubing.
for the carb side, find a tall closed element air cleaner to attach the pipe to. like something off a big block truck.
Old Apr 15, 2004 | 05:35 PM
ivanribic's Avatar
ivanribic
Also check the thread "mud in the carb" which is only a couple pages back in this forum. It was suggested to me that I cut a hole in the firewall and then run a tube through and seal it. This could easily be done with an old school 'snout' type air filter assembly, turned with the snout facing straight back and inserted through the whole. As long as you don't have water coming over your dash, inside the vehicle, you'll be okay. There were some other good ideas there too but I think the firewall intake was the best I heard.
Old Apr 15, 2004 | 09:41 PM
proeliator's Avatar
proeliator
Geez, and I didnt think you guys would take me seriously because it involved cutting into your firewall. Anyways, yea, that is the sure fire best way to keep your intake charge clean. Even snorkles get coated in mud and their performance suffers.
Old Apr 16, 2004 | 01:09 AM
ivanribic's Avatar
ivanribic
Of course we take you seriously . . . it's just baby steps ya know. Couldn't bring myself to cut metal a few months back and now I'm getting all kinds of crazy ideas. I figure if anyone is going to bother running a fugly ol' snorkel up their pillar and cut a hole in the fender to run the intake then they shouldn't have a problem with a little hole in the firewall that no-one will see.
Btw, got my cowl induction scoop today. I forsee a weekend of fiberglass fun and then we'll see how much water gets in my carb.
Oh, one last thought, if you do run a standard snorkel like the LR type Idio posted turn your inlet backwards. Otherwise a giant spray of water and mud will dump right down it when you hit the water. Nothing like putting a friggin funnel over your intake.
Old Apr 16, 2004 | 05:03 AM
hillbillydad
im thinking that that idea of running it into the glove box is a good idea. then silicon the crap outta it were it goes through the fire wall. that might actually work. get some pvc pipe like 3 inch and run it in and put like a k&n cone filter on it.
Old Apr 16, 2004 | 09:58 AM
KJKozak2's Avatar
KJKozak2
I thought of running 2 pieces of flexible exhaust tubing out the sides of the stock air cleaner and under the cab. Connect those to PVC that turns out and up at the cab corners like stacks. Dual snorkles! Just maks sure you at least match the square inches of intake that you already have.
I eventually gave up on the snorkle idea and made my own cowl induction hood scoop and customized the stock air cleaner. It shows in the "mud in the carb" discussion.
Kevin K.
