SES light on got some codes need help?
Old Jul 30, 2010 | 09:23 PM
shark1979's Avatar
shark1979
just put my HPOP back in tonight. started the truck up and got a ses light. checked the codes and this is what i got
P1209,P1211, and P0541. what do you guys think. how long will it take to get the air out of the oil lines?
Old Jul 30, 2010 | 09:27 PM
F350-6's Avatar
F350-6
Probably 20 miles or less. 40 - 50 miles tops.
Just make sure the oil level is topped off and you have no leaks.
Old Jul 30, 2010 | 09:34 PM
shark1979's Avatar
shark1979
how much oil goes in the resivor on top of the HPOP, do i need to keep checking that? she does sound rough is that just the air?
Old Jul 30, 2010 | 09:39 PM
F350-6's Avatar
F350-6
Once you've started the truck and it's run, you don't need to worry about the HPOP reservior. It gets it's oil from the oil pan. Just make sure the oil level is reading full on your dipstick and you're good.
Any air introduced into the oil rails in the head will cause the truck to run rough. IPR or HPOP work will let less air in than an injector replacement. That's why I said 20 miles as a guess to clear the air out.
Old Jul 30, 2010 | 09:46 PM
shark1979's Avatar
shark1979
what about the ses light ? thanks for the info chris
Old Jul 31, 2010 | 05:38 PM
shark1979's Avatar
shark1979
so i figured out what the codes are but what do they mean
p0541 air intake heater, got that covered
p1211 icp not controllable, that is from the Dp tuner right?
p1209 injection control system pressure peak fault, no idea
will the 1209 code hurt anything to drive truck? what causes this fault?
Old Jul 31, 2010 | 05:50 PM
shark1979's Avatar
shark1979
forgot to add my ICP pressure is around 3300-3800 ,not sure what normal is
Old Jul 31, 2010 | 06:24 PM
F350-6's Avatar
F350-6
The SES light is being caused by your ICP codes, which is probably being caused by your DP-Tuner when you get on it. It's all completely normal. The SES light goes out after a little bid of regular type driving, right?
Old Jul 31, 2010 | 07:05 PM
shark1979's Avatar
shark1979
no the light comes on as sooon as i start truck
Old Jul 31, 2010 | 07:09 PM
F350-6's Avatar
F350-6
Is your 3300 psi at idle or under acceleration? Have you tried starting in a different tune? What are you using to read the pressure?
Old Jul 31, 2010 | 07:16 PM
shark1979's Avatar
shark1979
scan gauge to read pressure. 3300-is at idle. the CEL light goes off when i put in in any other tune than stock. i guess i am just a little nervous beacuse it sounds real rough kinda like a rod knock, but it goes away. i guess that is from the air in lines?
Old Jul 31, 2010 | 07:35 PM
F350-6's Avatar
F350-6
What happens to the reading if you unplug the ICP sensor. You should be down in the 500 psi or so range at idle. Your 3300 psi reading is likely causing your rough idle. The computer is supposed to ignore the reading when it's off that much, but the tuner may be interfering with the default ICP tables.
Old Jul 31, 2010 | 07:57 PM
shark1979's Avatar
shark1979
with the dp out of truck still have 3000 at idle. unplug icp sensor truck starts romping. will it hurt it to drive. could this be caused by the IPR? i just had all that apart but just replace orings nothing else?
Old Jul 31, 2010 | 08:39 PM
F350-6's Avatar
F350-6
I can't imagine you've really got 3000 psi at idle. That's way too much for such low rpm's I would think. Did you see what the reading changed to when you unplugged the ICP?
If your ICP is really up over 3,000, then I'm guessing the IPR is stuck. What does IPR % show on the gauge? The truck won't start with the IPR unplugged will it?
Old Jul 31, 2010 | 08:52 PM
shark1979's Avatar
shark1979
with the icp unpluged the gauge read 13000 and the truck romps! the icp% is 4.6. the truck will start with the ipr unpluged. with it unpluged i have 3000 psi at idle
