Motor moves, window doesn't.
Old Aug 19, 2009 | 05:33 AM
Boz86's Avatar
Boz86
Originally Posted by 86F150302
My driver side is doing the same. I went to buy the "gear kit" and they are $29.99 locally. Went on Ebay and found a brand new motor (not rebuilt) for $28.00 shipped.
So when I get paid tomorrow im going to order the whole new motor.
I ended up buying a new Dorman motor after the NAPA rebuilt one I installed didn't work.
I'd rather put a new motor in that keep hassling with rebuilts that don't last as long.
Old Aug 31, 2009 | 10:47 PM
Sycostang67's Avatar
Sycostang67
I finally got this fixed, we carried a new gear at work for $18. When I took the old gear out, I noticed it wasn't actually a gear that was ruined. There is a large plastic gear on one side and a small metal gear on the other side. They are connected by three plastic ***** or blocks. I'm not sure what they were since I had nothing left but plastic bits. Strangely enough, my new gear and old gear were completely different diameters and the new metal gear was twice as thick as the old one. I was able to separate the new assembly which had solid rubber blocks and use them to connect my old gears. Everything works as it should now.
Old Sep 1, 2009 | 12:31 AM
86F150302's Avatar
86F150302
Those rubber blocks are called "Window Regulator Gear Plugs" I just bought a set today from AutoZone for $7.99
Part # 74410
If anyone else needs them.
Old Sep 1, 2009 | 11:10 AM
Sycostang67
Thats a handy bit of info.
Old Sep 1, 2009 | 03:29 PM
Eddiec1564's Avatar
Eddiec1564
I used 3/8's nuts in place of those plastic rollers, never had a problem again them turing into plastic bits! Been 10 years on them no issues at all.
Old Sep 1, 2009 | 07:18 PM
86F150302's Avatar
86F150302
Did the nut trick make your window clunk when all the way up or down? Only reason I didn't do that is I heard it makes your window motor alot noisier.
Old Sep 1, 2009 | 10:41 PM
Sycostang67
The gear plugs I got from the new gear were solid rubber, just flexible enough for me to squeeze the metal gear into the plastic one. I dont see them failing the same way the plastic ones did.
Old Sep 2, 2009 | 03:18 PM
Eddiec1564's Avatar
Eddiec1564
Nope, as long as they are the same size as those rollers, no clunking. Now in my car, the 3/8's nuts were little smaller than those rollers, so it does clunk!
Old Sep 3, 2009 | 12:37 AM
Sycostang67
I just found those gear plugs at my work, same part number too. I'm thinking I will buy them, put them in the gear I already bought and return it to get my $20 back. That way I am only out the $7 for the plugs.
Old Sep 3, 2009 | 02:41 AM
86F150302's Avatar
86F150302
Just put mine in tonight. Worked perfect
Old Sep 3, 2009 | 04:03 AM
86F150302's Avatar
86F150302
Before
After
Old Sep 3, 2009 | 05:48 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by andym
You can also go to Ford and get a rebuild kit for the motor. I've had to do this twice to my Bronco, once for the driver's side, once for the rear window.
This is what Ford sells, it's not a rebuild kit per se, as it only replaces the plastic drive gear that is notorious for stripping.
DOAZ62234A24B .. Power Window Motor Gear Kit
MSRP: $31.60 // FTE sponsor: Y2KFORDPARTS.COM price: $22.75.
Note: This kit is also available from parts stores, but...there are TWO different kits.
You want the kit that fits 1970 and later, not the kit that fits 1965/69.
The plastic window roller has nothing to do with the window motor. It's present whether you have power windows...or not.
The roller attaches to a stud on the window regulator's arm, then fits into the channel that's attached to the door glass.
What usually happens: The roller breaks, the window jams up in the channel, or falls down into the door.
D6AZ5323240A .. Window Roller / Use with or without power windows.
Fits: 1980/91 F100/350, Bronco, Econoline / 1976 and later passenger cars.
MSRP: $7.88 // Y2KFORDPARTS.COM price: $5.68.
1992 and later F150/350, Bronco, Econoline: The roller is not available by itself, it only comes with the window regulator.
Old Sep 3, 2009 | 10:09 AM
  #28
Sycostang67
Thats exactly what mine looked like, nothing but bits.
Old Sep 3, 2009 | 02:45 PM
  #29
Eddiec1564's Avatar
Eddiec1564
Make sure you grease the gear really good, that old dried out stuff is not much help. On one of my window motor's it was hard as a rock!
Old Sep 3, 2009 | 03:09 PM
  #30
NumberDummy
The Ford p/window gear kit comes with a bottle of grease.
