Auto. Climate control???
Old Aug 16, 2009 | 06:39 PM
DBANDGB's Avatar
DBANDGB
You guys are experts,you bailed me out before. Tried to find a mercury website like this one, but to no avail. I have an 89 mercury grand marquis with auto climate control.nice and cold and functions normally 90% of the time. Sometimes the compressor seems to not come on soon enough & real warm air comes out for about 4 minutes & then the comp. Starts & it stays cold. It will do this periodically. There must be a sensor in the car to control this.am i correct & if so where is it & could this be the problem or any other suggestions? Thanks
Old Aug 16, 2009 | 07:43 PM
projectSHO89's Avatar
projectSHO89
Check your compressor clutch gap first.
Old Aug 17, 2009 | 09:49 PM
dstig1's Avatar
dstig1
+1 on ProjectSHO89. Gap should be probably in the 0.014-0.030" range. Not 100% sure on the spec for this old car, but that is a common range for Ford's compressor clutches. I bet you are in the upper range or above. If so, then pull the clutch and remove a shim or 2 to get it back in spec.
Old Aug 20, 2009 | 04:01 PM
DBANDGB's Avatar
DBANDGB
Thank you guys. This will be my first thing to check
Old Aug 21, 2009 | 09:34 AM
n4aof's Avatar
n4aof
Originally Posted by DBANDGB
YTried to find a mercury website like this one, but to no avail.
There are a few decent Crown Vic sites that will cover your MGM. www.crownvic.net is about the best that I have found -- it doesn't come close to FTE but it can be helpful
Allstar recovory
Oct 23, 2013 11:55 AM
CRobertson
May 27, 2013 10:43 AM
2011f150js
2009 - 2014 F150
13
Mar 29, 2013 08:36 AM
1997fordf350
Aug 9, 2012 05:23 PM
cougar1985
1997 - 2003 F150
Feb 1, 2007 10:15 PM
