FX4 or Not?
I pulled a carfax and it was clean and no noticable damage or repairs under the truck. The guy said it came that way from the factory. I took it to my cousin who owns a body shop and he said it has not been wrecked but he was unsure if they came without decals or not.
Does anyone here know if they made an 04 FX4 without decals?
Also it has a cam phaser issue and the guy said that is why he wanted out of the truck. He did not get specific on the cost to fix the problem but when cold it is silent as can be and once warmed up it starts to sound like a diesel on the driver side. You can not hear it in the truck but on a tank of gas I did the math and got 17.67 mpg with about 70% highway miles after picking it up. So I am happy with the mpg but the tick is annoying.
Does anyone know if it will do damage or is this something that is a simple fix? The guy said it started about 15k miles ago or 61k miles. It has always had Valvoline 5-20 but I have always been a penzoil fan myself. I usually run 5-30 in cars or trucks but I have not owned a 3v 5.4 before either.
Any info on the cam phasers or stickers would be appreciated.
Thanks,
Rod
what color are the fender flares? (if any)
lariat = painted to match and smooth texture
Lariat = Honeycomb style grille
Lariat = wood trim
Cam Phaser noise:
just means the possibility of an early failure exists.
in addition, you need to use a Motorcraft FL-820s oil filter. Alot of truck owners use inferior oil filters
the FL-820s filter is superior to others in that respect
The cost to repair this noise is going to run you in excess of $1,500 if you pay a shop. A few more $$$ and you can get a slightly used short-block.
Thanks for the info. on the cam phasers also. I think you are right when it isn't worth dealing with until it becomes something larger than just an idle noise.
I agree on the oil filter. I grew up on fords and the FL1A was always needed on a 300 straight six or you would get engine noise on start up.
Thanks again,
Rod
<a href="http://s540.photobucket.com/albums/gg359/muddedprairie/?action=view¤t=jan09004.jpg" target="_blank"><img src="http://i540.photobucket.com/albums/gg359/muddedprairie/jan09004.jpg" border="0" alt="Photobucket"></a>
<a href="http://s540.photobucket.com/albums/gg359/muddedprairie/?action=view¤t=1232377848.jpg" target="_blank"><img src="http://i540.photobucket.com/albums/gg359/muddedprairie/1232377848.jpg" border="0" alt="Photobucket"></a>
Here are mine
