Modular V10 (6.8l)
2000 v-10 real mods
Old Aug 15, 2009 | 05:37 PM
rancid's Avatar
rancid
2000 v-10 real mods
are there any work to be done inside the motor, higher compression piston head work, cam, it just seems 300 hp is low for a motor this size. anybody seen one with a turbo.
Old Aug 15, 2009 | 08:19 PM
Skoda's Avatar
Skoda
seen one with a turbo why yes. the users name is happyhour he turbo'd his V10 drop his name in a search. Best way to get more kick hands down, gears, supercharger/turbo, tuner, exhaust system
Old Aug 15, 2009 | 10:15 PM
Fordfanatic4life's Avatar
Fordfanatic4life
keep in mind the engine wasnt build for HP its built for towing/hauling loads with gobs of TQ.
Old Aug 15, 2009 | 10:48 PM
rancid's Avatar
rancid
well mabey 2 small turbos and spool it early on the rpm,s.
Old Aug 15, 2009 | 11:10 PM
Pinky Demon's Avatar
Pinky Demon
With trucks, it's all about the torque. My Ranger only makes about 146 some horses, but 200 some lb. ft. on a 3.0. It's the same reason the 7.3L was only 200 some HP, but 535 lb. ft. of torque.
Old Aug 15, 2009 | 11:18 PM
rancid's Avatar
rancid
what about higher compression piston, why is the 5.4 so buildable and the v10 is the same engine with 2 more pistons.
Old Aug 16, 2009 | 12:21 AM
ScubaCat's Avatar
ScubaCat
You can only go so high with the CR before you run into big detonation issues, especially under heavy load. Anything you can do to a 5.4L you can do to a 6.8L, it just costs more.
Old Aug 17, 2009 | 08:12 PM
v10turbo's Avatar
v10turbo
or one big one works too!
Mustangking1
Jan 24, 2017 09:15 PM
sealer700
May 1, 2016 05:08 PM
Bigtom04
Sep 15, 2015 08:22 PM
Polkster
Sep 6, 2014 09:39 PM
crazed87bronco
May 11, 2012 10:12 AM
