Crack in Frame?
Old Aug 15, 2009 | 12:36 PM
00f250sd's Avatar
00f250sd
Crack in Frame?
I was doing dome degreasing today and found what looks to be a crack. See attached pic. The upper part of the picture is the power steering box. The Radiator is out at the moment. Can I weld that up?
Old Aug 15, 2009 | 07:55 PM
93 mix 'n match's Avatar
93 mix 'n match
looks to me that its just a rusted coating. i got something similar in the exact same spot.
Old Aug 15, 2009 | 08:24 PM
00f250sd's Avatar
00f250sd
Its definately a crack. But on the plus side, the frame is boxed there. However a crack still can't be good
BTW '92F-250 4x4
Old Aug 15, 2009 | 08:26 PM
93 mix 'n match
well if its defiantly a crack, then weld it up.
Old Aug 15, 2009 | 08:27 PM
Jermafenser's Avatar
Jermafenser
The horizontal crack? I would see how deep it is. Probably could just weld it up.
Looks like you better replace the core support, too.
Old Aug 15, 2009 | 08:37 PM
00f250sd's Avatar
00f250sd
Yes, the crack that goes left to right near the rivet. It goes down to the other part of the frame.
Old Aug 15, 2009 | 08:45 PM
Diesel_Brad's Avatar
Diesel_Brad
Drill a 1/8 hole at the end of the crack to keep it from spreading then do a good deep penatrating bead
1984_IH6.9_Project
Jan 24, 2017 08:50 AM
Montync
Apr 22, 2016 01:33 PM
BORDERBUM
47
Apr 11, 2016 09:18 AM
Hokie007
23
Jan 2, 2016 09:28 PM
PsRumors
WTB - Parts & other
Feb 8, 2011 01:39 PM
