#@Z$!* Bed Bolts!
Old Aug 15, 2009 | 03:56 PM
Roger T. Pipe's Avatar
Roger T. Pipe
#@Z$!* Bed Bolts!
OK, I'm in the process of removing the bed from my '96 250 4WD and got all 5 out with no problems whatsoever...however, the last one (it's always that one, isn't it)? is killing me! Its the one in the middle, the short, carriage-bolt on the drivers side. I had to get a swivel u-joint socket to get up to it and torqued the hell out of it. Finally it broke loose, only for me to discover that I was spinning it...apparently the square on the top of the bolt rounded and now its spinning in the hole...are there ANY tricks/cheats/tools etc to get this last one out? I blew the better part of today doing this!
Thanks
Roger
Old Aug 15, 2009 | 04:01 PM
Conanski's Avatar
Conanski
Weld a nut on top of bolt so you can get a wrench on it.
Old Aug 15, 2009 | 04:02 PM
Volvo92906's Avatar
Volvo92906
Ive seen people weld a nut onto the top of the carriage bolt to put a wrench on there and hold it while they take the nut off the threads.
[edit] Conanski beat me by a second...
Old Aug 15, 2009 | 05:00 PM
Spennyman84's Avatar
Spennyman84
I had the same problem on mine. I took a cut off wheel and cut the lip off of one side of the carriage bolt. Then I took a screwdriver and jammed down beside the bolt. When it spun it hit the screwdriver it stopped. All I had to do then was remove the nut.
Old Aug 15, 2009 | 06:36 PM
Brain's 97 Diesel's Avatar
Brain's 97 Diesel
Put a wrench on the head and mark the head then cut the two sides off and hold it in place w/ wrench and zip the nut off. You'll need a helper. Replace the bolts w/ the new style torx head incase you ever have to do this again. Also put anti-seeze on threads when you put it back together.
Old Aug 15, 2009 | 07:10 PM
fishforlife2007's Avatar
fishforlife2007
when i took mine out, lets just say that a grinder and a B.F. punch were my best friends... grind down the bolt close to the bed but not on grinding on the bed.... position punch on center of grinded down bolt.... whack with a rather large hammer.. and presto! no more bed bolt.... in fact i am still missing that bed bolt on my truck to this day..... i want to replace all of them with the newer f150 bed bolts that have the torx head on em, but am having trouble finding a set... anyways, best of luck to ya!
Old Aug 15, 2009 | 07:19 PM
Staveys150's Avatar
Staveys150
heat up the nut and it will come right off
Old Aug 15, 2009 | 07:28 PM
fishforlife2007
ya......rite...... i tried that with a combo of pb blaster.....long story short it was a waste of gas and pb.... it was right about then i grabbed my handy dandy grinder...
Old Aug 15, 2009 | 08:57 PM
Diesel_Brad's Avatar
Diesel_Brad
Grinding the head of is just going to F*%@# you. It woulnt go thru the bed(carrage shank) . Weld a nut to the head and hold it w a wrench, then just buy regular bolts to replace the carage bolts.
Old Aug 15, 2009 | 08:59 PM
94XLTFLAREI6's Avatar
94XLTFLAREI6
Hey, the title of this thread sounded like me when I took my bed off back in the spring! I had 3 spinning... and no welder to attach a nut as someone suggested, GREAT IDEA...
One of them turned a little before it spinned so i just slipped a hacksaw under the head and sawed the head off. The other two I drilled out, was a lot of drilling but it will work.
I just used regular head bolts when I put it back together. Bedliner covers them anyway, no need for fancy bolts, not to mention you can take it apart again easier.
Roger T. Pipe
13
Sep 16, 2020 04:34 PM
leafs_11
Jul 27, 2017 06:32 PM
Greg Rogers
WTB - Parts & other
Aug 21, 2016 07:45 AM
Roger T. Pipe
May 20, 2012 02:20 PM
Roger T. Pipe
Feb 16, 2012 05:02 PM
