What does IDI mean?
Old Aug 14, 2009 | 01:02 AM
bcarless's Avatar
bcarless
What does IDI mean?
I've read this alot on here and don't know what it means. What does IDI stand for? Any other abbreviations I should know for an '89 7.3L?
Old Aug 14, 2009 | 01:13 AM
300/6 Freak's Avatar
300/6 Freak
indirect injection
Old Aug 14, 2009 | 03:09 AM
jmmartin's Avatar
jmmartin
anything you come across that ya wanna know, ASK!!! Everyone will tell you, no matter what you ask, its not a dumb question, its just information you havent learned yet...
Old Aug 14, 2009 | 07:51 AM
luthrobediesel's Avatar
luthrobediesel
It means the fuel is injected in a precombustion chamber with a glow plug in it. The fire gets sprayed out into the cylinder kinda. The next generation trucks used the DI direct injection powerstroke. That one squirts the fuel dead center of the cyilinder and it has mexican top hat pistons for improved fuel swirl and mixture. The fuel squirts right on top of the piston and gets curled around in the cylinder becuase of the shape of the piston. The IDI has a regular flat piston. More abrevieations you could hear for the IDI is IP means injection pump, GP glow plugs, FSS fuel shutoff solenoid, VRV vacuum regulator valve(regulates vacuum to the modulator valve in an automatic truck)
Old Aug 14, 2009 | 09:51 AM
jedstamm's Avatar
jedstamm
What I haven't been able to figure out yet is why the direct inject systems didn't get better fuel mileage than the IDI's. Direct inject is much more efficient than indirect that one could easily assume you'd get better fuel mileage. This has always been the strike against Cat. engines as they weren't direct inject like the Detroits, and they got much poorer fuel economy. I'm surprised the 7.3 direct injects don't get upwards of 10-20 percent better fuel mileage than the old IDI's.
Old Aug 14, 2009 | 12:58 PM
johnboggs21's Avatar
johnboggs21
IDI means easy to work on reliable engine that makes good power.
Old Aug 14, 2009 | 09:16 PM
rupejosh's Avatar
rupejosh
luthrobediesel and johnboggs21 both have the perfect answers have a cold one guys!!
Old Oct 18, 2012 | 01:59 PM
Carly Phillips's Avatar
Carly Phillips
Johnboggs21, what does E40D mean?
Old Oct 18, 2012 | 02:07 PM
91dirtydiesel's Avatar
91dirtydiesel
It's an automatic transmission
Old Oct 18, 2012 | 02:23 PM
6.9 diesel nut's Avatar
6.9 diesel nut
Electronically controlled- 4 speed-with OverDrive. It's the replacement for the mechanical C6 auto 3 speed. For manual transmissions, the T19 is the older 4 speed non-overdrive tranny made by Borg Warner. It has the non synchronized granny gear. This tranny was last used in 1986. The other manual tranny is the ZF5. (4 speed with overdrive) There where two ZF5s. One was the earlier ZF5-42. The other was the identical but slightly beefier ZF5-47. The ZF5 ran from 87 all the way into the Powerstroke era. The ZF5 is the most common swap in IDIs. The replacement for the ZF5 was the ZF6. (5 speed with overdrive) Rarely swapped into an IDI, the ZF6 was used on the Super duty pickups until 2008.
Old Oct 18, 2012 | 05:39 PM
hairyboxnoogle's Avatar
hairyboxnoogle
DI only about 10% more efficient than IDI (so ive read) and in my experience not only does our IDI get better mpg than the DI 7.3, it also makes more power per CC of fuel. So im lost on the whole less efficient thing too. I know when IDI was introduced it was the "new" diesel tech. ran quieter, better mileage, better power and less emissions.
Old Oct 18, 2012 | 07:07 PM
6.9 diesel nut
I know a guy who has a 2000 Stroker and gets 20 MPG. My bro gets around 12MPG with his 99 Stroker. Funny how I get better fuel mileage and my truck is older. Got to love IDI. Very simple to work on and the parts are relatively inexpensive.
Old Oct 18, 2012 | 08:42 PM
Onus's Avatar
Onus
I think the mpg is better on the idi do the the compression ratio difference.
Idi's are 21.5:1
7.3 psd 17.5:1
The higher the compression ratio the more efficient.
Old Oct 18, 2012 | 09:34 PM
fellro86's Avatar
fellro86
That is the major part, as thermodynamics in general shows that with higher compression is higher efficiency. Look up Carnot Cycle, that is the ultimate ideal efficient cycle that all power cycles are compared to. By theory, higher compression will net better return, however in the real world, there of course is mechanical limits to what compression can truly be run.
Old Oct 22, 2012 | 11:31 AM
RA31925's Avatar
RA31925
The T-19 is actually synchronized in all four forward gears. It was the T-18 that was nonsynchro'd on first.
